05 de Abril de 2026, 22:19 *
Autor Tema: Pepakura Designer 6.1.2 Multilingual (x64)  (Leído 34 veces)
« : 03 de Octubre de 2025, 00:22 »
Free Download Pepakura Designer 6.1.2 (x64) Multilingual Fast Links | 20.4 Mb
Pepakura Designer is a Windows application which makes unfolded patterns from 3D data. Pepakura Designer features to automatically unfold 3D polygon-mesh models, and allow you to edit them. Pepakura Designer allows you to create real paper craft models from digital data!
You can try Pepakura Designer with no charge. (The data exporting feature is activated with purchase of the license keycode.) Note that Pepakura Designer does not have 3D data design features. You require 3D data before starting to use Pepakura Designer. Pepakura Designer supports common 3DCG file formats. Recommended 3DCG software is Metasequoia. You can use it for 3D model design at no charge. Pepakura Designer reads Metasequoia files with high compatibility.
One Button Unfolding
An unfolded 3D model pattern will be generated once you press the button.
Useful Toolset for Layout Editing
Pepakura Designer provides a simple and useful toolset for layout editing.
The Move, Rotate, and Join/Disjoin Parts editing tools, and the Adding Flaps support to arrange the layout.
Assemble Assistance
Pepakura Designer assists in the assembly process.
For example, ID numbers are assigned to edges, so you can understand the pairs of edges to be glued together. The positions of the pairs to be glued together are indicated by an arrow.
Exporting
Pepakura Designer supports the export in several file formats, including BMP, PNG, GIF, JPG, EPS, DXF, and PDF.
Texture Setting
By switching the textures on and off, you can assemble the color model or the white model, whichever you prefer.
You can also change the texture images on Pepakura Designer.
Operating System:Windows 8/10/11(64bit)
https://tamasoft.co.jp/pepakura-en/
1hln8.Pepakura.Designer.6.1.2.x64.Multilingual.rar.html
