07 de Abril de 2026, 05:32 *
Autor Tema: Easy Cut Studio 6.016 (x64) Multilingual + Portable  (Leído 39 veces)
« : 21 de Octubre de 2025, 22:40 »
Free Download Easy Cut Studio 6.016 (x64) Multilingual + Portable Fast Links | 20.7/15 Mb
The complete solution for designing, printing, cutting and print+cut. It gives you the ability to cut any TrueType font, OpenType font, graphics, SVG, PDF, as well as your own original designs with your cutting Descriptionter. This awesome vinyl cutting software even supports vectorize your images and built-in shape library includes hundreds of vectorial designs ready for cutting. With the intuitive user interface, Now anyone can cut designs like a pro!
Draw your own designs
Drawing and Designing couldn't get any easier! This powerful vinyl cutting software comes with a suite of various shape drawing and editing tools to draw and edit any shape directly on the mat. Easily draw unique shapes, modify signs, create logos, edit images, customize text with fonts on your computer plus special effects. Easy Cut Studio will make your design and cut your shapes easier than with any other sign-making software in the market today. It is a little design powerhouse for vinyl cutting.
Image Tracing & Vectorizing
Unmatched image vectorization, Simply use the powerful tracing tool to create cuttable outlines from any imported raster graphics (including PNG, JPG, GIF, PSD, PDF, BMP, TGA, TIFF, etc.) or scanned images. Easily create accurate vector paths ready for cutting or make further editing.
Import/Export most file formats
Import various file formats, including PNG, SVG, EPS, PDF, AI, GSD, SCUT, WPC and other popular vector formats as editable objects. giving you the power to cut any shape and custom artworks. You can also export your design to SVG, PDF, PNG, FCM, TIFF, JPG, and BMP format.
Print and Cut (Contour Cut)
Print to Cut made easy, fast and accurate. Automatic creation of registration marks for print and cut applications. Easily print your artwork and then cut out around the printed image using your cutting Descriptionter, which is perfect to create decals and stickers. User control over registration size, thickness and offset will help the cutter find the contour cut marks easily.
Working With Layers
Easily create complex designs using multiple layers, grouping to organize the display order of objects. Using Layers can help you more control over how you organize, edit and cut objects with Easy Cut Studio. The Shadow Layer option will create cuttable shadows from any shape.
Weld Text and Shapes Together
Welding is an advanced option allows you to make overlapping text and shapes to become a single shape, by joining shapes together wherever an overlap occurs. There are two ways to combine shapes/letters together: welding and joining.
Design and Cut Rhinestone Templates
Easily convert designs into rhinestone templates and make your own custom rhinestone designs with typeable rhinestone ready fonts. Specify stone size and spacing to make a rhinestone template and lattice shapes. Just select an object on the screen mat, and then choose "Rhinestones" from under the "Effects" menu to bring up the Rhinestone window shown below.
SVG to FCM Converter
SVG to FCM Batch conversion workflow is unmatched by any vinyl cutter software on the market. Easy Cut Studio will allow you to spend less time converting SVG to brother ScanNCut FCM file and more time cutting and playing with paper.
More features:
Text on arch tool and text on path tool.
Place text or objects on bezier paths.
Convert text to outlines/paths.
Creating multiple copies of the same object.
Node editing tool.
Creating the registration marks.
Layout and special effects for your text and shapes.
Cut font files already installed on your Mac or Windows.
Create shadowed mat effects.
Stencil function for bridging interior shapes.
Unlimited undo/redo
Choose from over 250 pre-made shapes from the built-in library.
WYSIWYC Interface - What you see is what you cut.
Generate jigsaw puzzles with full control.
Use any bitmap image to create a texture.
Multi-color gradient fill function with linear and radial options.
Scan images directly into the software.
Option to cut only selected objects.
Mirror or flip images before cutting.
Supports USB, serial, parallel, Bluetooth, ICP/IP and etc.
Language Supported: English, French, German, Italian, Spanish, Portuguese, Chinese (Simplified), Dutch.
Operating System:Windows 11 / 10 / 8.1 / 8 / 7 / Vista / XP
https://www.easycutstudio.com/
qr0k4.Easy.Cut.Studio.6.016.rar.html
qr0k4.EasyCutStudioPortable6.016.rar.html
