06 de Abril de 2026, 01:20 *
Autor Tema: Disk Drill Enterprise 6.1.1159 (x64) Multilingual Portable  (Leído 39 veces)
« : 16 de Noviembre de 2025, 21:47 »
Free Download Disk Drill Enterprise 6.1.1159 (x64) Multilingual Portable Fast Links | 20.5 Mb
From high-level business to home relaxation, modern life revolves around data. We all know that sinking feeling of a missing file. Fortunately Disk Drill is here to help with advanced file recovery software on all of your connected devices and files. Download Disk Drill, click "Recover" and watch as your day gets better.
Platform Independent
Disk Drill is powered by multiple data recovery algorithms that read NTFS, FAT32, EXT, HFS+ and many other file systems. Even obscure file types are accessible using our software.
Fixed & Mobile Storage
Recover your lost data on system disks and external devices, including all types of memory cards and USB drives. If you can connect it to your computer, Disk Drill can find your lost data.
Quick and Simple
Disk Drill tells you if your files can be recovered for free. Just a few files deleted? 500MB of free data recovery on us!
Complete Data Recovery
There are countless ways to lose your data. Power failure, failed boot drives, partition damage, an accidentally emptied Recycle Bin, a virus attack... these are only the most common. Data loss can be a frustrating, infuriating or downright terrifying experience. For fast, reliable file recovery software, download Disk Drill for Windows to recover your lost data no matter what the cause.
Multiple Scan Options
Was your data lost just a few minutes ago? On Windows, your chances of free file recovery are much higher if you act right away and Disk Drill is the perfect way to retrieve these lost bits. Even if Disk Drill wasn't installed when the files were deleted, Disk Drill knows where to look and can bring them back to you in a flash. Accidentally deleted files are an easy target for Disk Drill's Quick Scan function. Typically, when a file is deleted, the file contents are still there on the drive and only the filename has been marked as removed. Quick Scan takes just a second to find the list of recently deleted items. You then choose which ones you wish to recover and Disk Drill recovers them as if they'd never been lost!
Powerful Session Management Means Flexible Scanning
Recovering data from large hard drives or memory cards can be a time consuming process. In an ideal world we would be able to sit around and wait, but that is not always the case, which is why Disk Drill features powerful session management features. Scans can be paused, stopped or resumed anytime. This means that you do not need to wait for a full scan to finish if you have already found the file you were after, simply stop the scan and recover it. If you need to pause a scan to step away or turn off your computer, no problem! Come back and resume a scan anytime exactly where you left off in a prior session.
Premium Data Protection
Even before your data is lost, download Disk Drill to start protecting your files right now. With Recovery Vault enabled, our software provides an added level of protection for all your sensitive and important locations. Quite simply, Recovery Vault stores detailed information about every file that you delete, think of it as an extended Recycle Bin in your system without the need for extra disk space. That way, if you change your mind it's a simple matter of a click to restore it back.
More Than File Recovery Software, Full Partition Recovery
Disk Drill for Windows is a free data recovery software. Its powerful scanning engine is unmatched in versatility and scanning power. You can recover up to 500MB completely free. Advanced scanning options like Quick Scan for fast, easy scans and Deep Scan for more complex, deeper searches means that your files can easily be recovered by Disk Drill. Recovery goes beyond just files with Disk Drill's full partition recovery feature. Included with Disk Drill are several powerful partition healing algorithms, too. Combining these tools into a single data recovery suite (Disk Drill) means you have the best possible chance to recover not only your files but your entire storage medium. Disk Drill is especially helpful after erroneous formats on partitions, by scanning the entire drive (and not just the new partition) it is possible for Disk Drill to recover the original partition and many or all associated files.
The Ultimate File Recovery Toolkit
Not having the right tool makes the job much harder which is why Disk Drill has everything you need for complete free file recovery. In addition to simply being able to recover files, Disk Drill can do much more with an advanced suite of powerful features wrapped in an easy to use interface. Check out some of the tools & features of Disk Drill:
Scanning Choices
Multiple advanced recovery algorithms including Quick Scan and Deep Scan for more complex situations.
Recovery Vault
The best way to fix lost files is to prevent file loss! Disk Drill's Recovery Vault protects your valuable files and data.
ISO/DMG Backup
Don't want to restore multiple files on your computer now? No worries, Disk Drill can backup your recovery results into a mountable DMG or ISO!
Pause & Resume
We know life happens, Disk Drill offers a powerful pause and resume feature to start and stop scanning at anytime, perfect for large drives.
USB Drive Recovery
Disk Drill can scan and recover from USB drives, memory cards and other forms of portable media. If your computer can read it, we can scan it.
Partition Recovery
Lost or damaged partition? No problem. Disk Drill features an advanced partition recovery tool and several healing algorithms, too.
Flexible Data Recovery Software
In most cases lost data is so valuable it's nearly impossible to replace. Disk Drill can recover deleted data from virtually any storage device. This includes internal and external hard drives, memory cards and more from desktops, laptops, workstations, even cameras or iPods. If your computer has direct access to a device's memory, Disk Drill will be able to scan it for lost data. You don't have to worry about the recovery method, Disk Drill will quickly analyze the problem and choose the most effective approach.
Requirements:Windows 7 SP1+, 44 MB
https://www.cleverfiles.com
9c4rg.Disk.Drill.Enterprise.6.1.1159.x64.Multilingual.Portable.rar.html
