07 de Abril de 2026, 02:57 *
Autor Tema: Mestrelab Research Mnova 16.0.0 Build 39276 Win x64  (Leído 40 veces)
« : 24 de Noviembre de 2025, 09:16 »
Free Download Mestrelab Research Mnova 16.0.0 | 588.1 mb
Mestrelab Research S.L.has releasedMnova 16.0.0is a powerful, multi-vendor software suite designed to seamlessly process and analyze data from NMR, LC/GC-MS, and Electronic & Vibrational Spectroscopic techniques. Our platform is built to work with a wide range of instruments, offering unmatched versatility and precision for your analytical needs
Owner:Mestrelab Research S.L.
Product Name:Mnova
Version:16.0.0 (39276)
Supported Architectures:x64
Website Home Page :
https://mestrelab.com/
Languages Supported:english
System Requirements:Windows *
Mestrelab Research S.L. proud to introduce the latest version of Mnova, featuring updated products such as Mgears 2.7, Mnova Hub 1.1, Chrom Cal 1.1, and qNMR 3.3. This release delivers a range of novel features, performance improvements, and essential bug fixes-designed to streamline your workflows and boost your analytical productivity.
1. Mnova Scripting with Python
Python has become the leading programming language in the scientific community, thanks to its versatility, readability, and powerful libraries for data analysis, automation, and visualization. With Mnova's integrated Python Interpreter, users can harness this power to automate tasks, customize analyses, and interact programmatically with Mnova data.
In this version, the Python Interpreter has been significantly enhanced with:
-    New scripting functionalities
-    Updated examples to help you get started
-    Expanded documentation for better support and learning
Whether you're a beginner or an experienced coder, now is the perfect time to start scripting in Mnova. Open the Python Interpreter, explore the examples, and take control of your workflows with custom automation tailored to your needs.
Figure 1. Mnova Scripting with Python video series
2. NMR - Allotrope ASM
With Mnova 16, users can now import and export NMR data in the ASM format, enhancing compatibility with Allotrope[1] - compliant systems and workflows.
For 1D and 2D NMR experiments, Mnova saves the following information in ASM:
-    Experiment data and experiment parameters (spectrometer, field, solvent, time, etc.)
-    Processing parameters (baseline correction, phase correction, etc.)
-    Peak and multiplet analyses (for 1D NMR only)
Close
Figure 2. New ASM format supported in Mnova.
The Allotrope Foundation is a scientific consortium focused on developing data standards to enable seamless data exchange, system interoperability, and improved data integrity across the pharmaceutical and life sciences industries. One of its key initiatives is the Allotrope Data Format (ADF), which includes the Allotrope Simple Model (ASM) - a lightweight, standardized format designed to store analytical data along with its associated metadata.
3. Mnova - Command Palette
The new "Command Palette" is a streamlined search box designed to accelerate your workflow by providing quick access to commands and actions across the application. Inspired by modern development tools, the "Command Palette" lets you search, filter, and execute commands without navigating menus. Whether you're processing spectra, launching plugins, or configuring settings, everything is just a keystroke away.
Figure 3. Command Palette - just hit the shortcut 'Ctrl + .', start typing, and find the functionality you need faster than even before.
4. Mnova - Advanced Plug-ins Indicator
A new color-coded status icon has been added to Mnova to help you effortlessly manage your Advanced Plug-ins.
Close
Figure 4. Double-clicking the icon opens the Advanced Plug-ins dialog, where you can view installed and available plug-ins, check version status, and perform updates as needed.
Each color represents a specific status:
-    Dark grey - No status data available (typically just after Mnova installation)
-    Green - All Advanced Plug-ins are up to date
-    Red - One or more updates are available but not yet installed
-    Yellow - A restart is required to complete an update (e.g., after adding a new plug-in)
-    Orange - Updates available and a restart is required
A simple yet effective visual enhancement that provides a clear, at-a-glance overview of your plugins' status directly within the Mnova workspace.
5. Mgears 2.7
Mgears 2.7 delivers major enhancements to improve automation, flexibility, and system integration in analytical workflows.
5.1 Mnova Hub now available in Mgears as a new input
Mgears can now retrieve input data directly from LOGS or ZONTAL data management platforms through Mnova Hub for analysis, simplifying data integration processes.
Close
Figure 5. Mnova Hub integration in Mgears as new input source.
5.2. Portable Mgears settings
It is now possible to save and share scripts, templates, and auxiliary files effortlessly, as part of the Mgears settings (.mgrs files). This simplifies sharing and re-using methods significantly.
5.3. NoSQL DB connector
A new connector is available for saving Mgears analysis results to a NoSQL database. This feature will enable Mgears users to utilize all the capabilities of NoSQL databases, such as searching, comparing results, fast reviewing, retrieving statistics, and more.
Close
Figure 6. New checkbox to save results to a NoSQL DB within the Output tab.
6. Mnova Hub 1.1
Mnova Hub 1.1 now integrates with LOGS, a cloud-native platform serving as a centralized repository for analytical data, allowing users to retrieve, modify, and store data in LOGS directly from within Mnova.
Close
Figure 7. Handling data using filtering options within the new LOGS provider for Mnova Hub.
Additionally, improvements to the ZONTAL provider enhance usability and expand support for .zip files containing '.mnova' documents.
7. Chrom Cal 1.1
Chrom Cal 1.1 brings several powerful new features including support for internal standards, a new quadratic regression model, new input options with retention time and m/z, and the ability to handle multiple targets and calibration curves within a single workflow, among others.
Close
Figure 8. 1- Multiple target results including internal standard and calibration modes; 2- Specific calibration curves;
3- Multiple peak identification.
Close
Figure 9. Analysis results using m/z as input and EIC as the quantification chromatogram.
8. qNMR 3.3
The latest version of the qNMR plugin (3.3) brings numerous enhancements to streamline Concentration and Purity workflows. With a refined interface, new settings, and improved performance in batch analysis (Gears Concentration and Purity), qNMR is now more efficient and intuitive.
And more...
Mnova 16 also includes numerous optimizations, stability improvements, and bug fixes across the platform - from the main interface to individual plugins and bricks.
Mnovais the natural evolution of our very popular application MestReC. However, it is more than a new version of MestReC. Whilst including all the NMR processing and analysis functionality present in MestReC, it is a completely new development and a completely new concept which will open up a whole new range of possibilities when storing and sharing data within organizations, changing the way in which scientists process and report NMR and LC/GC/MS data. Mnova has been designed to make NMR and LC/GC/MS both more convenient and more powerful, and to give the user improved results with minimum effort. The program provides a variety of conversion facilities for most NMR and LC/GC/MS spectrometer and chromatogram formats and includes all the conventional processing, displaying, and Descriptionting capabilities of an NMR program, as well as more advanced processing techniques with a very user friendly graphical interface.
Training Courses
Mestrelab Research S.L.is a leading software developer, based in Spain and founded in 2004 as a spin-off of the University of Santiago de Compostela. The company's mission is to develop software solutions which become the universal processing and analysis interface between analytical instrumentation and chemists.
0h4n2.Mestrelab.Research.Mnova.16.0.0.rar.html
