06 de Abril de 2026, 11:26 *
Autor Tema: Soluling Enterprise 1.0.1085  (Leído 96 veces)
« : 15 de Diciembre de 2025, 20:57 »
Free Download Soluling Enterprise 1.0.1085 | 669.6 Mb
Soluling localization tool is the easiest way to create and maintain multilingual software, documents, and data. Add Soluling as a part of your development process. No matter if you use continuous localization or waterfall localization, Soluling works with your process.
Soluling has the features you need
Scan your files locally on your build server or development machine - no need to send source code to a localization service or to give a localization service access to your repo.
When scanning, Soluling completely decouples strings from your files, letting translators and developers work simultaneously.
Soluling lets you localize everything: strings, layout, images, colors, etc.
Soluling has visual editors that show the original and localized UI in real time.
Soluling knows even the most complex resource formats. No need to limit only to a simple JSON.
Soluling knows the project file formats. For example, instead of selecting dozens of .resx, .xaml, and/or .rc files you only select one: .csproj, .vbroj, .sln, .exe, or .dll file.
During your build process, Soluling creates up-to-date resource files and injects translations into them.
Output files that Soluling creates are ready to be deployed.
Soluling understands your file formats
Desktop projects: Visual Studio, .NET, .NET Framework, WPF, Windows Forms, Visual C++, Delphi, Qt, and more.
Web projects: ASP.NET Core, ASP.NET Framework, Blazor, Angular, React, Vue, Django, Go, Ruby on Rails, PHP, Java, Magento, and more.
Mobile projects: Android, iOS, UWP, Xamarin, FireMonkey, and more.
Resource formats: ResX, XAML, Text, XML, JSON, YAML, INI, GetText/PO, TS, scripts, RC, and more.
Document formats: Markdown, HTML, HTML Help, SVG, Word, Excel, PowerPoint, DITA, Help & Manual, and more.
Databases: SQL Server, MySQL, PostgreSQL, SQLite, Access, InterBase, Firebird, and more.
Other formats: TMX, SalesForce, SubRip, WebVTT, and more.
100+ supported formats.
Soluling increases your translation speed and quality
Machine translation: Amazon, DeepL, Google, Microsoft, ModernMT, and more. Get a candidate popup as you type.
Translation memory with fuzzy matching. Get a candidate popup as you type.
Terminology support with stemming. Soluling highlights those words that exist in the termbase. Click a highlighted word to get a translation and copy to the translation field.
Pseudo translation, spell checking, import and export.
Excellent support for grammatical numbers (e.g., singular and plural) and grammatical genders (e.g., male, female and neutral).
Real-time and batch translation validation: Soluling automatically finds the errors as you type and can even fix them.
With Soluling, localization is easy
Complete list of the features.
Support for build automation with flexible command-line tool.
Excellent support for continuous localization.
Internationalization API that extends native APIs.
Hundreds of samples.
Automatically import your existing translations. Switch from other tools easily.
Excellent support.
Features by editions.
System requirements:Windows 7 (TLS 1.2 enabled) or later. Windows 10 or later recommended.
https://www.soluling.com/
ccna0.Soluling.Enterprise.1.0.1085.rar.html
