07 de Abril de 2026, 11:10 *
Autor Tema: SpinFire Insight 2025.3.0 (x64) Multilingual  (Leído 45 veces)
« : 08 de Enero de 2026, 22:56 »
Free Download SpinFire Insight 2025.3.0 (x64) Multilingual Fast Links | 463.7 Mb
SpinFire Insight gives your entire organization a uniform way to view, interrogate, and translate CAD files. It's the same SpinFire technology automotive manufacturers have trusted for more than 15 years, now available in a revolutionary all-access format.
COMMUNICATE
With an intuitive interface available in more than 10 languages, SpinFire Insight lets anyone leave feedback, change requests, and annotate on CAD files.
COLLABORATE
Share models across internal and external teams with multi-CAD support. SpinFire Insight covers all your CAD-sharing needs, and works at the office, at home, and on the road.
COMPREHEND
When managers, salespeople, marketers, and vendors can actually see the parts you make, everything changes. SpinFire Insight transforms organizations by putting pictures to part numbers.
Comprehensive Features
SpinFire Insight gives you and your team everything you need to view and interrogate assemblies, parts, and drawings in all major 2D and 3D CAD formats.
Gain insight on an item's volume, weight, surface area, and center of mass. Quickly calculate the sum of connected edges selected, or the area they define.
Dimensions and distances
Use Smart Dimensioning to automatically display an item's dimensions, including:
Linear
Edge length, thickness, point to point, point to edge, surface to surface
Radial
Arc diameter, arc center, radius, distance between centerline, circle by three points
Tube
length with centerline length and all bend points and export to csv
Model analysis
Use SpinFire's highlighting features to call out aspects such as:
Differences between similar models
Draft angles and projected areas
Wall thickness
Surface curvature
Format-neutral
SpinFire supports all major 2D and 3D CAD formats.
Intuitive Interface
For years, manufacturers have chosen SpinFire for its ease of use. SpinFire Insight extends the same level of intuitive design to your organization, reducing training time.
https://spinfire.com/solutions/spinfire/
97y4c.SpinFire.Insight.2025.3.0.x64.Multilingual.rar.html
