05 de Abril de 2026, 21:52 *
Autor Tema: BitRecover MSG to PDF Wizard 26.1  (Leído 23 veces)
« : 26 de Enero de 2026, 14:10 »
Free Download BitRecover MSG to PDF Wizard 26.1 | 101 Mb
MSG File to PDF Converter Software to Batch Convert MSG to Adobe PDF without Outlook.
Convert Emails.msg, Calendar.msg, Tasks.msg & Notes.msg into PDF Document.
Offers a Dual file selection option to convert single / multiple MSG files to PDF.
Allows to batch Convert Outlook messages to PDF file with attachments.
Extract MSG File to PDF with embedded message files (messages within message).
Allows to transform all MSG file Attachments as PDF Documents Pages.
Convert .msg to .pdf files in Black & White / Grayscale Mode (non-searchable).
Provides 11+ File Naming Options when converting MSG Files into PDF Format.
Supports MSG Files of MS Exchange Server 2003-2013 and MS Office Outlook 2003-2019.
Why MSG File to PDF Software?
The All-in-one MSG to PDF Converter tool is a versatile file conversion application designed to batch convert Outlook messages to PDF with efficient algorithms. Users can convert selective Outlook email to adobe PDF files after successful activation of this program. You can also convert *.msg to *.pdf with attachments & can add Outlook MSG files or directories to the program panel easily. This export task does not affect MSG file formatting and properties when you are converting the MSG file to Adobe PDF. Since the tool has a clear and quick to use GUI, any user can save the MSG file as a PDF file quickly. No experience or technical skills are needed to open MSG files in a PDF format. For conversion, both ANSI and UNICODE MSG files are well-supported.
Supports Converted PDF Files to All Platforms
This software is a one-stop MSG to Adobe PDF format conversion solution. It conducts a seamless conversion of emails from Outlook MSG Files to PDF format. Users can convert MSG file to PDF Adobe regardless of the kind of attachment it contains. In addition, there is no need to install MS Outlook for conversion when exporting Outlook email MSG to Adobe PDF. And it's very able to replace MSG with PDF for all versions of Adobe PDF Reader with this tool. Adobe (11.0, 10.0, 9.0, 8.0, 7.0, 6.0) and its previous releases are supported . In addition, almost all computers and systems will be able to access and display PDF (Portable Text Format) files, such as Windows OS, Linux, macOS, and Android Phones.
OS: Windows 11 & all below
Processor: Intel® Pentium 1 GHz processor(x86,x64) or equivalent
https://www.bitrecover.com/msg-to-pdf/
mcuij.BitRecover.MSG.to.PDF.Wizard.26.1.7z.html
https://turbobit.net/smfym71yeig8/mcuij.BitRecover.MSG.to.PDF.Wizard.26.1.7z.html
