04 de Abril de 2026, 13:50 *
Autor Tema: Advanced CSV Converter 7.92  (Leído 29 veces)
« : 21 de Febrero de 2026, 07:40 »
Free Download Advanced CSV Converter 7.92 | 3.2 Mb
Advanced CSV Converter is a powerful tool for converting CSV to DBF, Excel(XLS,XLSX), TXT, HTML, PRG, XML, SQL, RTF. To convert a file, the program offers a wizard-driven interface, which walks you through the conversion step by step. Using the wizard, you select the input file, choose the target format and folder.
If necessary, you can set the conversion filter by example and select columns you want to exclude from the process. Once the conversion is started, the program extracts data from CSV file and ports it into a list of data fields, which are then saved to the specified formats. Conversion is accurate and quick thanks to the well-written algorithm.
Below is an overview of the features you'll get by choosing Advanced CSV Converter.
Convert CSV to 10 formats. Advanced CSV Converter lets you export a CSV file to DBF (dBase III/IV, Visual Foxpro), Excel files:XLS,XLSX, SQL, TXT, Fixed Width Text, HTML, PRG, XML, RTF.
Set filters with Advanced CSV Converter. The program lets you set conversion filter by example and perform query by example. This gives you more flexibility in defining the parameters of the output file.
Batch conversion with Advanced CSV Converter. Besides single files, the program lets you convert more than one file in one go. To do so, select the folder with CSV files in the input field of the wizard, configure export settings and start conversion.
Command line support. You can use the graphical user interface to convert CSV files. However CSV Converter also lets advanced users do the conversion from the command line.
Convert CSV in 3 steps. The conversion of CSV files requires only a few steps. The first thing you need to do is to select the input file for conversion. Then you select the output format and destination folder. The third step is to set export options, such as filtering, type of delimiter and others.
Save on buying multiple apps. Usually you'll need to buy several applications if you want to do the conversion to multiple formats. With CSV Converter, you get a single tool to export CSV to other formats.Advanced CSV Converter does not require any external drivers such as ODBC or BDE.
Operating System:Windows 7, 8/8.1, 10
http://www.dbf2002.com
Visit All My News
pg9uj.Advanced.CSV.Converter.7.92.rar.html
https://turbobit.net/fw55qrcwpr5e/pg9uj.Advanced.CSV.Converter.7.92.rar.html
