09 de Abril de 2026, 01:43 *
Autor Tema: How is European handicap different from Asian handicap?  (Leído 299 veces)
phocohanoi7
Interesado
WWW Email
« : 04 de Diciembre de 2024, 03:49 »
European Handicap differs from Asian Handicap in several key aspects, primarily in how they are represented and the outcomes they cover.
European Handicap (EH) Explained: EH is more commonly known as a three-way handicap bet. It operates similarly to Asian Handicap but is simpler to engage with. For a match, the 'penalty' is given to the stronger team.
Points are either added or subtracted before the event begins. Your bet wins or loses based on the final result adjusted by the handicap you placed.
Unlike in the Asian Handicap market, where a draw is impossible, this type of bookmaker in usa provides three potential betting options – win, draw, and lose, hence why it is called a three-way handicap.
EH also uses whole number handicaps in contrast to the fractional handicaps used in Asian Handicap. Additionally, it functions similarly to the 1X2 bet.
Here's an example to help you understand the concept better:
Manchester City plays at home against Watford with a 100% chance of winning.
EH would favor the underdog team, which in this case is Watford, with a number of goals that Manchester City must surpass to be considered the winner.
Regardless of the final result of the match, if the European Handicap is 3 goals, Manchester City is only considered the winning team if they win by more than 3 goals.
Therefore, betting on Watford will win the bet even if they lose by less than three goals. The match is considered a draw if Man City is favored and wins by exactly three goals.
Asian Handicap (AH) Explained: The AH betting market is ideal if you favor something less common than 1X2.
In summary, AH involves giving the stronger team a handicap goal, with the weaker team having a higher goal difference. To win the bet, you must back the team with the higher points difference, considering their handicap or corresponding advantage.
The goal of AH is to ensure that a match does not end in a draw. By eliminating the draw option, you only have two choices: bet on the home team or the away team.
For instance:
Suppose you bet £1000 on the weaker team, with Team A as the weaker home team with an Asian Handicap of 0.75 and Team B as the stronger away team.
Odds=1.90 To win the bet on Team A, they must win or at least end the match with a draw.
Conversely, if Team A loses by more than two goals, you will lose your bet. Conversely, if you bet on Team B, they receive a -0.75 goal handicap.
Therefore, to win the bet, Team B must win by at least two goals. If they win by a single goal (0-1, 1-2, or 2-3), you only win half of your bet. Moreover, if the match ends in a draw or Team A wins, you will lose.
AH can vary between a quarter ball handicap (0.75 and 0.25), half ball (0.5), and even full balls (1, 2, etc.), with the full ball (sometimes the entire goal) being the most common.
Now, although Asian Handicap may sound complex at first glance, it actually simplifies things by ensuring the winner of the handicap bet. Moreover, the Asian Handicap betting market is known for its low variance and good odds compared to European Handicap.
The Difference Between European Handicap and Asian Handicap:
Although the two handicap betting markets may seem similar, their differences can be categorized into three parts: symbols or representatives, numerical variations, and match results.
European Handicap and Asian Handicap are two popular types of betting markets that offer handicaps in football betting.
Both systems are designed to balance the perceived strength difference between two teams by giving one team a virtual advantage or disadvantage, but they differ significantly in how they operate and the way outcomes are settled.
==> Learn some awesome bookmaker london here
Key Differences Between European Handicap and Asian Handicap:
European Handicap:
Let’s assume a -1 Handicap for Barcelona.
Barcelona (-1): This means Barcelona must win by more than 1 goal for the bet to win. In this case, Barcelona wins 2-1, so after applying the handicap (-1), the score becomes 1-1, which is a draw.
If you bet on Barcelona (-1), you lose the bet.
If you bet on the draw (-1), you win (because after applying the handicap, the match is a 1-1 draw).
If you bet on Manchester United (+1), you win (because they "draw" with Barcelona after the handicap).
Asian Handicap:
Let’s assume a -1 Handicap for Barcelona in Asian Handicap terms.
Barcelona (-1): The bet is void or a push because after applying the handicap, the match becomes 1-1. Your stake is refunded.
If you bet on Manchester United (+1), you win the bet, as they "draw" with Barcelona after the handicap is applied.
==> Learn some awesome top 100 bookmaker here
Choosing Between European and Asian Handicap:
European Handicap is simpler and more straightforward, especially for bettors who are familiar with traditional win, draw, or lose bets. It can be good for those who want to bet on a handicap draw or make their betting strategy more predictable.
Asian Handicap offers more flexibility, especially with quarter and half handicaps, and minimizes risk by eliminating the draw option and offering refunds.
It’s favored by experienced bettors who prefer more intricate betting strategies and seek to avoid losing full bets in tightly matched games.
Each system has its advantages depending on how much control and flexibility you want in your bet. Let me know if you'd like more examples or details!
