06 de Abril de 2026, 00:57 *
Autor Tema: Golden Software Surfer 31.1 Build 247 Win x64 English  (Leído 38 veces)
Conectado Conectado
« : 14 de Marzo de 2026, 09:25 »
Free Download Golden Software Surfer 31.1 (247) | 233.9 mb
Golden Software, a developer of affordable 2D and 3D scientific modeling packages, is pleased to announce the availability ofSurfer 31.1 (247)is a grid-based mapping program that interpolates irregularly spaced XYZ data into a regularly spaced grid.
New Features and Improvements
-    3D View:
.        3D Grids: Image slice: change interpolation mode for pixels (like color relief layer)
.        3D PDF Export: use names from Contents in the Model Tree (instead of object type)
.        Drillholes: create depositional and erosional surfaces from drillhole contact picks
.        Fly-Through: save recording in MP4 format
.        Isosurface: add "Ignore" option for handling NoData interface
.        Import Image Orientation: set Orientation to a polyline or polygon in a vector file
.        Performance: reduce property view refreshing during camera movement
.        Record window
.        Vector Data: add Point Labels
.        Vector Data: rename "Features" property page based on layer type
-    Assign Coordinate System: add EPSG code in parameters pane for each CS
-    Base import: DWG/DXF: add option to import each layer from file as separate Base layers
-    Coordinate systems:
.        Map: Assign Now could be active if you set units for an unreferenced coordinate system
.        Show the EPSG code in Properties
.        All UTM/Mercator projections should be linear and accurate
.        Changing Target coordinate system: instead of warning with OK, prompt to Assign Now
.        Favorited coordinate systems that are corrected and never modified should inherit the correction
.        Issue warning when users try to change the Source coordinate system
.        When overlaying referenced layers in unreferenced maps, use one of the coordinate systems for the combined map
-    Gridding method: 3D Nearest Neighbor for XYZC gridding
-    Import/Export DWG
-    Import DXF: elevation data stored as block attributes are not accessible in Surfer
-    Import/Export DXF: update DXF import and export to use the new/updated DWG functionality
-    Large Grids: Color Relief: General Properties: improve response time when changing Hill Shading Parameters
-    Legend:
.        Add \layername to template options (post, drillhole, and base layer)
.        Add contour layers as single-line or multi-line entry
.        Add Drillhole layers without symbology, and improve legends when drillhole layer does have symbology
.        Drillhole layer: row height should only be impacted by the properties that are shown
.        Middle align symbols and text in sample entries
.        Pie chart symbology: include "Fill sample size" with line props around the fill
.        Post layer: use \layername in default template when size is Fixed and color columns set to None or Explicit
-    Map Scale Bar: made sure the map scale bar object was named consistently within the program
-    Ribbon: new Help page
Fixes
-    3D View: 3D PDF/VRML Export: axis titles are not exported
-    3D View: Walk: WASD keys no longer move camera in Walk mode
-    Base layer: Legend links for invalid legends using old serialization should not be saved
-    Coordinate Systems:
.        Geotransformation of Lambert Nord France is not correct
.        EPSG: 3388 has incorrect coordinate system definition and does not account for 180 lat bound
.        Cannot change Map coordinate system from WGS84 UTM zone 14N to 15N
.        Portuguese National Grid and ETRS89/Portugal TM06 are not converting the coordinate system properly
.        Projection error converting from WGS84 UTM zone 23N to any other coordinate system
-    Crash after copying/pasting map, adding legend and saving
-    Crash in automation when importing a grid
-    Crash when cleaning up after graphics driver SEH exception
-    Download Online Maps: entering lat/lon extents is really difficult or impossible (TAB, clicking in another box or Paste doesn't work)
-    DXF Import: lines are straight when they should be curved
-    Groups: Symbols drawn in existing Groups are upside down
-    Internal Error when creating 3D view after using Set Limits (NormalizingTransform.cpp)
-    Internal Error when exporting 3D View to 3D PDF (TrPolymesh.cpp)
-    Internal Error when measuring (MeasureToolWnd.cpp)
-    Invisible layer using shared grid at the top prevents display in 3D View
-    Legend: Copy/Paste when contains a drillhole layer and a base layer causes Surfer to become unresponsive
-    Surfer Warning about unreferenced layers is either empty or too large to display on the screen when there are too many layers
Surferis powerful contouring, gridding, and surface mapping package for scientists, engineers, educators, or anyone who needs to generate maps quickly and easily. Producing publication quality maps has never been quicker or easier. Adding multiple map layers and objects, customizing the map display, and annotating with text creates attractive and informative maps. Virtually all aspects of your maps can be customized to produce the exact presentation you want.
Surfer Introduction Training Video
This video introduces Surfer, explains some of the key features of Surfer, and shows how easy it is to create a contour map in Surfer from x,y,z data.
Founded in 1983,Golden Softwareis a leading developer of affordable scientific graphics software. Its customer base includes over 100,000 users involved in environmental consulting, oil and gas exploration and extraction, mining exploration and extraction, engineering, applied science, business, education, and government in nearly 190 countries and territories. Golden Software offers four products: Surfer for gridding, contouring and 3D surface mapping; Grapher for 2D and 3D graphing; Voxler for 3D data visualization; and Strater for well log, borehole and cross section Descriptionting.
Owner:Golden Software
Product Name:Surfer
Version:31.1 (247)
Supported Architectures:x64
Website Home Page :www.goldensoftware.com
Languages Supported:english
System Requirements:Windows *
1yftd.Golden.Software.Surfer.31.1.247.rar.html
https://turbobit.net/eu0igs1zmpre/1yftd.Golden.Software.Surfer.31.1.247.rar.html
