Free Download GiliSoft File Lock Pro 15.7 Multilingual Fast Links | 129.6 MbGilisoft File Lock Pro - protect, encrypt files, folders, and drives in an easy way. Password protect your files, folders and disk drives in a reliable way.
Brief Introduction About Gilisoft File Lock Pro
Why do you need Gilisoft File Lock Pro? Most of us use our computers in a shared in environment with our family members, colleague or friends etc. But sometimes we may want set some permissions so that we can hide some files, folders and disks or actually restrict access to them.
GiliSoft File Lock Pro is the most advanced and easiest data protection tool. With this program, nobody can access or destroy your private data without password and you will never worry about data theft by malicious behavior and privacy leaks on shared computer. This data security software can restrict access to files folders and drivers: encrypt files, folders; hide files folders and drives to make them completely invisible; make files folders and drives read only; or password protect files folders and drives.
Exclusive Features of File Lock Pro
Hide Files/Folders/Drives
Make your private files/folders and drives completely invisible to anyone or any programs even under Windows Safe Mode.
Deny Reading Files/Folders/Drives
Locked files/folders or drives can't be opened, read modified, renamed, moved, deleted, copied without password.
Deny Writing Files/Folders/Drives
People can read the write-protected files/folders or drives, but can not modified, deleted, or renamed it without password.
Monitor Folder Changing and Write Log
Monitor a disk or a folder and its sub-folders when any operations or changes make by a user.
Powerful Self-protection Mode
Nobody can uninstall this software without password and you can hide this program in Invisible Mode. When someone enters wrong password more than 5 times, it will send alarm notifications to your pre-defined e-mail and the unknown login will be temporarily banned.
Easy to Use
With it you can use one password to Protect File Folder & Drive. You can lock a file or folder with windows explorer context menu or simply dragging and dropping it into the program's main window. When forget password, you can find lost password with your pre-defined e-mail.
Encrypt Data & Portable Version
Encrypt files and folders into an .exe file with AES encryption algorithm. After encryption, you can also open encrypted files or folders on other computer.
Safe Delete (File Shredder)
Remove sensitive data by overwriting it several times and make it unrecoverable.
Operating System:Windows 2000/2003/XP/Vista/7/8/10/11
Home Page -http://www.gilisoft.com/Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator10x8r.GiliSoft.File.Lock.Pro.15.7.Multilingual.rar.htmlDDownload10x8r.GiliSoft.File.Lock.Pro.15.7.Multilingual.rarFreeDL10x8r.GiliSoft.File.Lock.Pro.15.7.Multilingual.rar.htmlhttps://turbobit.net/6fcljufpkmjg/10x8r.GiliSoft.File.Lock.Pro.15.7.Multilingual.rar.htmlLinks are Interchangeable - No Password - Single Extraction
