06 de Abril de 2026, 01:22 *
Autor Tema: PneuCalc 8.0.3  (Leído 35 veces)
« : 15 de Marzo de 2026, 11:42 »
Free Download PneuCalc 8.0.3 | 7.8 Mb
PneuCalc is the only software application that provides an efficient workflow with many features to avoid design pitfalls and converge quickly and efficiently for an optimized design. Better design systems in a fraction of the time.
Designing or troubleshooting pneumatic conveying systems
Improperly designed conveying systems or process changes can wreak havoc on production lines with blockages in the system, irregular feed rates, or premature equipment wear. Understanding how the system parameters influence the behavior of conveyed material is key to efficient and reliable pneumatic handling of bulk materials.
Making smart design choices
Comprehensive
Design and troubleshoot both pressure and vacuum systems
Calculate and display dilute, dense and mixed modes of conveying
Includes material saltation velocity calculator tools
Automatically display the Geldart material chartgroup classification
Analyze
Detailed pipe segment display shows impact of design changes and can help display root causes of system bottlenecks
Automatic parameter verification enables best design solutions for sloping convey lines, acceleration zone length, min/max material speed, refluxing in vertical sections, and max pressure
Time saving
Custom, reusable and shareable material and gas properties database
Prototype design options on the fly for gas flow, pipe size and pipe diameter stepping
Export valuable data for reporting, specifications, equipment datasheets and more
Accepts both imperial and metric unit input data and converts results automatically
Intuitive
New dynamic visual interface
Easy drag and drop pipe routing
Create and validate conveyor line layout with the geometry display
Select pipe components from standard library
Affordable logo
Cost effective
See our licensing rates to boost productivity and help you make smart design choices
Robust
+20 years proven reliable calculations
Compatible with PneuCalc 6.0 and 6.2
Useful in multiple
https://www.pneucalc.com/
rt9ee.PneuCalc.8.0.3.rar.html
https://turbobit.net/r8uu6a0jb9ob/rt9ee.PneuCalc.8.0.3.rar.html
