05 de Abril de 2026, 05:18 *
Autor Tema: meet me download for windows 7  (Leído 20 veces)
evasingle
Forero de Honor
« : 18 de Marzo de 2026, 17:06 »
Hello, visitor!
Article about meet me download for windows 7:
The documentation set for this product strives to use bias-free language. For the purposes of this documentation set, bias-free is defined as language that does not imply discrimination based on age, disability, gender, racial identity, ethnic identity, sexual orientation, socioeconomic status, and intersectionality. Exceptions may be present in the documentation due to language that is hardcoded in the user interfaces of the product software, language used based on RFP documentation, or language that is used by a referenced third-party product.
  >> ENTER THE SITE <<
Learn more about how Cisco is using Inclusive Language. Book Title. Feature Configuration Guide for Cisco Unified Communications Manager, Release 15. Meet-Me Conferencing. View with Adobe Reader on a variety of devices. Results. Chapter: Meet-Me Conferencing. Meet-Me Conferencing. Meet-Me Conferencing Overview. Users can use Meet-Me Conferencing to set up or join conferences. A user that sets up a conference is called the conference controller. A user that joins a conference is called a participant. Meet-Me Conferencing Task Flow. Before you begin. Refer to the configuration documentation which came with your router and check for any settings which you may need to configure before proceeding with the Meet-Me Conferencing Task Flow. Procedure. Add the Meet-Me softkey to a softkey template. Optional . To make the softkey template available to phones, you must complete either this step or the following step. Optional . Use this procedure either as an alternative to associating the softkey template with the Common Device Configuration, or in conjunction with the Common Device Configuration. Use this procedure in conjunction with the Common Device Configuration if you need assign a softkey template that overrides the assignment in the Common Device Configuration or any other default softkey assignment. Enable advanced conferencing, specify the maximum number of participants, and specify when to drop a conference connection. Configure a Softkey Template for Meet-Me Conferencing. Use this procedure to make the Meet Me softkey available in the off hook call state. Procedure. From Cisco Unified CM Administration, choose Device > Device Settings > Softkey Template . Perform the following steps to create a new softkey template, otherwise, proceed to the next step. Select a default template and click Copy . Enter a new name for the template in the Softkey Template Name field. Perform the following steps to add softkeys to an existing template. Click Find and enter the search criteria. Select the required existing template. Check the Default Softkey Template check box to designate this softkey template as the default softkey template. If you designate a softkey template as the default softkey template, you cannot delete it unless you first remove the default designation. Choose Configure Softkey Layout from the Related Links drop-down list in the upper right corner and click Go . From the Select a Call State to Configure drop-down list, choose the call state for which you want the softkey to display. From the Unselected Softkeys list, choose the softkey to add and click the right arrow to move the softkey to the Selected Softkeys list. Use the up and down arrows to change the position of the new softkey. Repeat the previous step to display the softkey in additional call states. Perform one of the following tasks: Click Apply Config if you modified a template that is already associated with devices to restart the devices. If you created a new softkey template, associate the template with the devices and then restart them. For more information, see Add a Softkey Template to a Common Device Configuration and Associate a Softkey Template with a Phone sections. Associate a Softkey Template with a Common Device Configuration. Optional . There are two ways to associate a softkey template with a phone: Add the softkey template to the Phone Configuration . Add the softkey template to the Common Device Configuration . The procedures in this section describe how to associate the softkey template with a Common Device Configuration . Follow these procedures if your system uses a Common Device Configuration to apply configuration options to phones. This is the most commonly used method for making a softkey template available to phones. Before you begin. Procedure. Add a Softkey Template to a Common Device Configuration. Procedure. From Cisco Unified CM Administration, choose Device > Device Settings > Common Device Configuration . Perform the following steps to create a new Common Device Configuration and associate the softkey template with it, otherwise, proceed to the next step. Enter a name for the Common Device Configuration in the Name field. Perform the following steps to add the softkey template to an existing Common Device Configuration. Click Find and enter the search criteria. Click an existing Common Device Configuration. In the Softkey Template drop-down list, choose the softkey template that contains the softkey that you want to make available. Perform one of the following tasks: If you modified a Common Device Configuration that is already associated with devices, click Apply Config to restart the devices. If you created a new Common Device Configuration, associate the configuration with devices and then restart them. Associate a Common Device Configuration with a Phone. Before you begin. Procedure. From Cisco Unified CM Administration, choose Device > Phone . Click Find and select the phone device to add the softkey template. From the Common Device Configuration drop-down list, choose the common device configuration that contains the new softkey template. Click Reset to update the phone settings. Associate a Softkey Template with a Phone. Optional . Use this procedure as an alternative to associating the softkey template with the Common Device Configuration. This procedure also works in conjunction with the Common Device Configuration. You can use it when you need to assign a softkey template that overrides the assignment in the Common Device Configuration or any other default softkey assignment. Before you begin. Procedure. From Cisco Unified CM Administration, choose Device > Phone . Click Find to select the phone to add the softkey template. From the Softkey Template drop-down list, choose the template that contains the new softkey. Press Reset to update the phone settings. Configure a Meet-Me Conferencing Number. The Cisco Unified Communications Manager administrator provides the Meet-Me conference directory number range to users, so that they can access the feature. The user chooses a directory number from the range that is specified for the Meet-Me Number or Pattern to establish a Meet-Me conference and becomes the conference controller. Procedure. From Cisco Unified CM Administration, choose Call Routing > Meet-Me Number/Pattern . Enter the appropriate search criteria and click Find . In the list of records, click the link for the record that you want to view. Perform one of the followings tasks: To copy a Meet-Me number or pattern, click the Meet-Me number or pattern that you want to copy. The Meet-Me Number/Pattern Configuration window appears. Click Copy .
Download meetme for pc windows 10
Download meetme for windows 7
Download meetme for windows 10
Download meetme for pc windows 7
Meet me download for windows 7
