06 de Abril de 2026, 04:20 *
Autor Tema: Metric Halo Make Believe CGII v4.1.0.264  (Leído 13 veces)
« : 25 de Marzo de 2026, 16:24 »
Free Download Metric Halo Make Believe CGII v4.1.0.264 | 22.4 MB
With great power comes great responsibility.
Make it Good & Loud
Use CGII to make your masters loud without losing the clarity, density and heft of the original mix. Even if you are working with a mix that is already loud, you can give it a little extra, without adding unpleasant distortion and without flattening out the material and sucking the life out of the low end. At the same time you can control the true-peak level of the program to ensure that there are no inter-sample overs.
We've also included dither, a DC-block filter and complete LUFS/True Peak metering so that you can place CGII at the end of your master chain as a one-stop shop for final processing.
While CGII's original spec was to make things good & loud simultaneously, you will find that it is wonderful in a variety places in your mixing and processing chain.
Use the Loudness processor to excite harmonics. Use the Density processor to bring up the bloom and raise low-level clarity without affecting transients. Or simply put the incredibly transparent true-peak lookahead limit any place you need it.
https://www.makebelievestudio.com/plugins/cgii
http://peeplink.in/b5fecd92a00a
udw50.Metric.Halo.Make.Believe.CGII.v4.1.0.264.rar
udw50.Metric.Halo.Make.Believe.CGII.v4.1.0.264.rar.html
https://turbobit.net/6kwux3vpaov4/udw50.Metric.Halo.Make.Believe.CGII.v4.1.0.264.rar.html
