06 de Abril de 2026, 18:21 *
Autor Tema: Chaos Vantage 3.2.0 (x64)  (Leído 19 veces)
« : 25 de Marzo de 2026, 16:33 »
Free Download Chaos Vantage 3.2.0 (x64) | 932.4 Mb
Explore your most complex 3D production scenes ray traced in real-time. With Chaos Vantage, there are no time-consuming conversions. Simply drag and drop your complete V-Ray scene into Vantage and start exploring. There's also a direct live link available from 3ds Max, so you can use it just like a viewport.
Chaos Vantage requires an NVIDIA RTX series GPU.
Features:
Zero setup
Drag and drop your V-Ray scene into Chaos Vantage and start exploring. Unlike other real-time solutions, there's no geometry to optimize, UVs to unwrap, or lighting to bake.
Go big!
Chaos Vantage is built to handle huge scenes and billions of polygons. It's the fastest way for you to see your most detailed V-Ray scenes in real-time.
Easy to navigate
Navigating your scene is easy. Use controls similar to your 3D app, or move around just like playing a game. Walk up stairs and avoid walking through walls with automatic collision detection.
100% ray-traced quality
With fully raytraced and real-time rendering, Chaos Vantage uses physically based cameras, lights, materials, and global illumination for the most realistic results.
Simple and fast animation
Perfect for previsualization, you can create, edit, and render animation right from Chaos Vantage. Easily animate between cameras, apply transitions, arrange your sequence in the Animation Editor.
Live link
Get a live raytraced view of your scene with a live link from 3ds Max. Changes you make in your 3ds Max scene will instantly appear in Chaos Vantage.
OS: Microsoft® Windows® 10 RS5 (version 1809), update from October 2018, build 17763 or later
GPU Acceleration: DXR compatible GPU: NVIDIA RTX® series GPU with NVIDIA® driver 436.02 or newer in WDDM mode; recommended version 466.11
- System memory should exceed GPU memory (minimum 8 GB RAM)
Notes:
1 - Driver 460.89 produces incorrect results in materials and textures with Ampere (30XX) cards.
2 - GPU must be set to WDDM mode and not in TCC otherwise Chaos Vantage will not detect it.
3 - NVIDIA AI denoiser requires driver version 466.11 and newer.
https://www.chaosgroup.com/
lqt2m.Chaos.Vantage.3.2.0.x64.rar.html
https://turbobit.net/buvyalzfz51k/lqt2m.Chaos.Vantage.3.2.0.x64.rar.html
