06 de Abril de 2026, 04:31 *
Autor Tema: Royal TS 7.4.50318 (x64) Multilingual  (Leído 11 veces)
« : 25 de Marzo de 2026, 16:38 »
Free Download Royal TS 7.4.50318 (x64) Multilingual Fast Links | 297.5 Mb
Royal TS is an ideal tool for system engineers and other IT professionals who need remote access to systems with different protocols.
Optimize workflow and increase productivity! Royal TS makes it possible with our flexible user interface and outstanding team collaboration features. Not only easy to use, it enables secure multi-user document sharing.
Powerful Connection Management
Compatible with a variety of connection types
Using RDP, VNC, SSH based terminals, S/FTP or web-based interfaces?
No worries, Royal TS got you covered!
Built-in credential management. Safe team-sharing features.
Share a list of connections, without sharing your personal credentials.
Command Tasks and Key Sequence Tasks make it easy to quickly automate repetitive tasks.
SSH-based tunneling (Secure Gateway) support is tightly integrated in Royal TS.
Dynamic Folders allow you to dynamically import data from external sources.
Credential Management
Assign, reuse and link credential objects to connections and folders.
Connections can inherit credentials from the parent folder.
Access credentials from other documents and external sources.
Protected through Encryption
Sensitive data in your document is encrypted and can also be password protected. Lock down shared documents and keep passwords confidential.
Sharing Connections Securely
The ability to assign credentials to connections by name allows you to share the document containing the connections without compromising your credentials.
Automate repetitive Tasks
Streamline your workflow with Tasks. Use replacement tokens to access connection properties or credential information. Execute tasks in context of one or more connections.
Command Tasks
Create your own tasks to open and close VPN connections automatically. Common and useful tasks, like ping and traceroute are built-in and can be executed as needed.
Key Sequence Tasks
Key sequence tasks are used to invoke keyboard input in one or more connections. Automate long, complex and repetitive tasks and execute them in one or more active connections.
https://royalapps.com/
ql8gc.Royal.TS.7.4.50318.x64.Multilingual.rar.html
https://turbobit.net/k3itdrwnlds7/ql8gc.Royal.TS.7.4.50318.x64.Multilingual.rar.html
