06 de Abril de 2026, 04:24 *
Autor Tema: DP Animation Maker 3.5.48 + Portable  (Leído 10 veces)
« : 25 de Marzo de 2026, 16:42 »
Free Download DP Animation Maker 3.5.48 + Portable Fast Links | 24/122.8 Mb
Smart 2D animation software that lets you turn still images into live moving scenes. Create living, breathing worlds from your still image with minimum effort. DP Animation Maker lets you make natural scenes burst with vibrancy and give motion to people and objects.
Fun software, with a wide variety of uses
DP Animation Maker helps you make animated videos for lots of stuff. Whether for business or personal use, some of the most popular items people create with the software include:
- Animated videos
- Web banners
- YouTube videos
- Digital greeting cards
- Mobile phone backgrounds
- PowerPoint presentations
- Music videos
- Video footage
- And more!
Sky's the limit! So why settle for boring, static photos or slideshows? With DP Animation Maker you can bring your images to life by making waves crash at the ocean, snow fall on mountains, and flames flicker on candle wicks.
It's fast and easy-to-use
The good news is, you don't have to be a tech guru to use this software. Thanks to our easy-to-understand interface, no special skills are required. Anyone can use it. But tech savvy graphic artists benefit, too. That's because DP Animation Maker takes the guesswork out of the time-consuming programming aspect of the animation process. Artists can concentrate on image design and artwork instead. No matter your level of tech sophistication, our process is painless. Simply open an image, select an effect, add moving objects, export to your preferred format, and voila - you're ready to share your animation with the world. It's that fast. With the press of a button, you can adjust motion, speed, and other key elements of any moving object. Ready-to-use, animated images are available within minutes.
Plenty of features to choose from
Our prebuilt animations are designed to give you a lot of options. Whether you have a single image or need to create a long slideshow, DP Animation Maker has the rich set of tools you need to put all the pieces together. Once you select your images, it's easy to go from 'static' to 'alive' with our wide range of effects, stationary objects, moving objects, brushes, music, timing, and camera adjustment features. You can also import your own animated GIF files if you want to add more effects to them as well.
Effects
Give images the appearance of being underwater, of having a reflection, or of being on fire. After you select a desired effect, you can fine-tune the height of your flames or the speed of your waves by tweaking the adjustment settings.
Stationary & Moving Objects
DP Animation Maker gives you more than 60 objects to choose from in our standard pack, and over 200 in extension packs.
Brushes
Add even more variety to your creations with our powerful set of animation brushes. Use nature brushes to insert fire, streams, water, or blinking lights. Intensify object movements with geometric brushes that give you waves, drifts, zooms, and rotation. Or go with pattern brushes that provide pink and colored hearts, glittering and gold stars, and other custom patterns.
Music
Have the perfect song you want to include, too? You can. Our music upload feature lets you integrate MP3 audio files that will play during your movie. Simply choose songs and put them in your preferred playing order.
Camera Settings
You can preview your animation by adjusting the scene zoom and camera speed before you export your work. With DP Animation Maker, you can add and delete effects as frequently as you wish. It's a helpful way to experiment and be creative so you can get the look you want.
Many file formats give you flexibility
When you're ready to publish, DP Animation Maker exports your animation into several popular formats.
Animated GIF
This highly compressed format is great for the times you need smaller files sizes, such as when you're creating web banners.
AVI
One of the most common video formats, AVI files can be played on any computer or uploaded on YouTube
MOV
Ideal for playing videos on Apple's QuickTime, MOV files are widely-used. They offer non-professionals a straightforward way to create ready-to-watch movies while giving professional filmmakers a tool that's lossless and supports alpha channels.
PNG Sequences
If you want your animation as individual frames that you can put into other types of software, such as a video editor, PNG sequences provide an easy way to do so.
EXE
Not sure what kind of video player your audience has? No problem. When you export your animation as an EXE, it will play on any computer. There's no need for a specific player (e.g. QuickTime) or plugins.
Add animation to images, without spending a fortune
Can you find other software out there to do your animation work? Of course. But professional editions of software like Adobe Flash, Adobe Photoshop, or Autodesk 3ds Max can set you back hundreds or thousands of dollars. Not DP Animation Maker. Our software has an affordable price that everyone can afford.
Home Page-http://www.animationsoftware7.com/
gnj36.DPAnimationMaker3.rar.html
gnj36.DPAnimationMakerPortable3.5.48.rar.html
https://turbobit.net/s2vtlkzk5d6f/gnj36.DPAnimationMaker3.rar.html
https://turbobit.net/3rpjq6ey6pyq/gnj36.DPAnimationMakerPortable3.5.48.rar.html
