05 de Abril de 2026, 21:55 *
Autor Tema: Schoolhouse Test Professional Enterprise 6.1.174 + Portable  (Leído 22 veces)
« : 25 de Marzo de 2026, 16:44 »
Free Download Schoolhouse Test Professional Enterprise 6.1.174 + Portable Fast Links | 48.5/31.1 Mb
Creating and printing a paper-and-pencil test, quiz, or exam, has never been easier. Schoolhouse Test makes a time-consuming chore a whole lot easier and the result considerably more professional. Some of our customers have even hinted that creating tests with Schoolhouse Test can actually be an enjoyable process. If you're looking for a professional test generator that makes quick work out of creating paper-and-pencil tests, quizzes, and exams then Schoolhouse Test is the program for you.
And now version takes test creation to the next level. Schoolhouse Test brings high resolution display, multi-part questions, expanded references, an enhanced print manager, grouping, a solution view, and a whole lot more.
Quiz maker
You need a quick quiz for your science class. Schoolhouse Test can get the job done in minutes. Not only will you have a quiz ready for your next class but you'll have a quiz that can be easily randomized and given again in a week's time as a follow-up quiz. Or, using the built-in Question Bank (Pro editions), you can easily combine the questions from this quiz with questions from other quizzes for an end-of-unit test or an end-of-term exam.
Test maker
It's the end of your geography unit and you need to evaluate your students' learning with a nice test that includes some multiple-choice questions, a few short answer questions, maybe a matching question, and finally an essay question. Schoolhouse Test comes to the rescue again. You can design your test from scratch which is not as bad as it sounds if you're using Schoolhouse Test. In fact you'll be surprised at just how easy it is. Or, if you have been using quizzes to periodically check that your learning objectives are being met, you can simply use the Question Bank (Pro editions) to select and combine questions from the existing quizzes to make your test. Likewise, if you need an end-of-term or end-of-year exam, you can use the questions in your existing tests and quizzes to design your exam.
Exam maker
Now it's exam time and you need an exam to administer. Well, once again, Schoolhouse Test reduces even that monumental undertaking to a manageable task. Even if you're writing your exam questions for the first time it will go a lot faster than you expect it to. Even tricky-to-write question types like matching, order, and tables are surprisingly easy to produce. And if you have quizzes and tests that you have been using throughout the year to assess learning, you can use the Question Bank (Pro editions) to construct your exam from your existing questions.
Assess learning with 13 question types
With Schoolhouse Test you can design custom tests and quizzes to evaluate learning in any subject area using thirteen different question types:
- multiple-choice
- fill-in-the-blanks
- matching
- short answer
- list
- checklist
- table
- list with prompts
- order
- true/false
- essay
- diagram
- statements
Create your first quiz or test in minutes
Schoolhouse Test is a surprisingly easy to use and very intuitive test maker. It incorporates three views or work areas depending on the current task. You use the design view to construct your test or quiz, the document view to format the test and see exactly what it will look like when printed, and the answer sheet view to format the answer sheet and see what it will look like when printed.
Requirements:Windows  11,10, 8/8.1, 7
https://www.schoolhousetech.com
b3ltf.Schoolhouse.Test.Pro.Ent.6.1.174.Portable.rar.html
b3ltf.Schoolhouse.Test.Professional.Enterprise.6.1.174.0.rar.html
https://turbobit.net/ityqis98f18m/b3ltf.Schoolhouse.Test.Pro.Ent.6.1.174.Portable.rar.html
https://turbobit.net/yfyxsznpuew8/b3ltf.Schoolhouse.Test.Professional.Enterprise.6.1.174.0.rar.html
