06 de Abril de 2026, 13:23 *
Autor Tema: Neevia Document Converter Pro 7.7.0.286  (Leído 17 veces)
« : 28 de Marzo de 2026, 10:24 »
Free Download Neevia Document Converter Pro 7.7.0.286 | 41 Mb
Neevia Document Converter Pro is a software product that dynamically converts Microsoft Office 2007/2010/2013/2016/2019/365, WordPerfect, HTML, AutoCAD DWG/DWF, EML, MSG, PostScript and many other document types to PDF, PDF/A, PostScript, JPEG, TIFF, PNG, PCX, BMP. It operates in both a batch mode via directory or email scanning and in direct mode via a COM object or .NET component. Document Converter can be configured to recognize text - this is known as OCR - for the converting Image and PDF files and comes with support for printing the input files directly to a physical printer instead of converting them to PDF or Image.
With clustering support and multi-threaded conversion Neevia Document Converter Pro is the only document conversion software that offers 100% conversion stability.
Document Converter Pro is easy to install and is used by companies in the legal, pharmaceutical, insurance and in many other areas that generate voluminous documents. The goal of Neevia Document Converter Pro is to help your company create one PDF/Image standard that can be integrated into your workflow with ease and affordability.
Key features:
Unlimited number of conversions;
Multi-threaded conversion;
Multiple input folders, each with its own configuration;
Conversion scheduler;
Monitor and convert files from multiple eMail accounts;
Failover and high performance clustering support - more info;
Support for recognizing text - known as OCR;
No Adobe software required;
Support for over 300 file types;
Convert HTML files with support for CSS, SSL, Java and Flash images;
Convert MS Word hyperlinks/headings to pdf links/bookmarks;
Convert MS Word form fields into PDF form fields;
Font embedding, resolution, compression and multi-language support;
128/256 bits PDF encryption; Encrypt existing PDF files;
Convert MS Excel hyperlinks/headings to pdf links/bookmarks;
Convert MS Powerpoint hyperlinks/headings to pdf links/bookmarks;
PDF merge and split functionality;
Add watermark and stationery - unicode fully supported; Stamp existing PDF files;
COM object and .NET component included for on the fly conversion;
Run as a Windows service;
Convert to PDF, PostScript, TIFF (including Class F), BMP, PNG, PCX, JPEG;
Supported Operation Systems:
The operating systems listed here have been tested with Neevia Document Converter Pro and are officially supported:
Windows Server 2022 64-bit edition
Windows 11 64-bit edition
Windows Server 2019 64-bit edition
Windows Server 2016 64-bit edition
Windows 10 32-bit and 64-bit editions
Windows 8 32-bit and 64-bit editions
Windows Server 2012 32-bit and 64-bit editions
Windows 7 32-bit and 64-bit editions
Windows Server 2008 32-bit and 64-bit editions
Windows Vista 32-bit and 64-bit editions
Windows Server 2003 32-bit Web Edition, Standard Edition and Enterprise Edition
Windows Server 2003 x64 Web Edition, Standard Edition and Enterprise Edition
Windows XP Professional and Home Edition with Service Pack 1, 2 or 3
Recommended hardware:
Standard PC; 2GHz or faster compatible x86/x64 processor
RAM: 2GB RAM recommended, 1GB minimum
Hard-disk: 500MB free space recommended, 100MB free space required
Display: 16-bit display adapter recommended
https://www.neevia.com/products/dcpro/
gorhe.Neevia.Document.Converter.Pro.7.7.0.286.rar.html
