06 de Abril de 2026, 00:24 *
Autor Tema: HaneWin NFS Server 1.2.68 Multilingual  (Leído 10 veces)
Conectado Conectado
« : 29 de Marzo de 2026, 15:18 »
Free Download HaneWin NFS Server 1.2.68 Multilingual Fast Links | 1.2 Mb
The software implements a multithreaded NFS Server for all Windows platforms.
The implementation supports:
NFS 3, NFS 2, WebNFS and NLM protocol.
UDP as well as TCP connections.
Unix soft-links (symbolic links).
Unix hard-links on NTFS volumes
If supported symbolic links can use Windows reparse points.
Inodes for block- and character devices.
Implemented as Windows service and Windows application
Use of NTFS file id as inode for Windows 7 and higher
The installer contains the 32bit software and native x64 versions of the programs.
The NFS Server runs as a background service on Windows XP/VISTA/20xx/7/8/10/11. The necessary SunPRC PortMap Daemon is implemented as an independent service.
The NFS server application is a portable Windows application with a built-in SunRPC Portmapper.
Connections with the NFS Server are supported over UDP or TCP using NFS 3 or NFS 2 protocol. For connection setup the WebNFS protocol WebNFS (RFC 2055) and the Sun RPC based mount protocol is supported.
Multithreaded implemenation with a configurable number of UDP server threads and one thread per TCP connection.
https://www.hanewin.net/nfs-e.htm
p23c6.HaneWin.NFS.Server.1.2.68.Multilingual.rar.html
