06 de Abril de 2026, 00:24 *
Autor Tema: Embarcadero RAD Studio 13.1 Florence Win x64 English  (Leído 15 veces)
Conectado Conectado
« : 29 de Marzo de 2026, 15:19 »
Free Download Embarcadero RAD Studio 13.1 Florence | 10.7 Gb
Languages Supported: English, Français, Deutsch, 日本語
Updated: Added fixed release.  Reason: Minor adjustment in the licensing module naming system during the DelphiLSP process.
Embarcaderohas released RAD Studio, Delphi, and C++Builder 13.1 Florence is the next release of your favorite way to develop applications that run on Windows, macOS, Linux, iOS, and Android. This release focuses on quality improvements and includes significant enhancements to the C++ toolchain and the IDE.
RAD Studio 13 Florence - Release 1 (also known as 13.1) builds on the feature set of RAD Studio 13, enhancing existing features throughout the product and adding new capabilities. Highlights include a new Delphi Windows on Arm (Arm64EC) native compiler, updates for the latest Android and iOS platforms, improvements to the Delphi LSP engine, and the introduction of a new FireMonkey Style Designer. The release also brings numerous IDE enhancements, UI modernization updates, and ongoing improvements to VCL, FireMonkey, C++Builder, database access, and web technologies.
What's New in RAD Studio 13.1
Delphi Arm64EC Native Compiler Toolchain
Target the next generation of Windows on ARM devices with your existing codebase
RAD Studio 13.1 and Delphi 13.1 introduce a new native target platform for Delphi compiler: Windows on Arm. Delphi now supports creating native Arm binaries that run on Windows Arm devices (or Windows on Arm virtual machines running on Arm Macs), without using the Intel emulation layer. This allows developers to expand the native Windows support, building native applications for Win32, Win64 Intel and Win64 Arm using the same source code. Existing Delphi applications can generally be recompiled for the new target platform.
Android API Level 36 and iOS 26 Support
Compliance for the latest mobile OS and app store requirements
RAD Studio 13.1 adds support for Android API level 36.1, a mandatory requirement for publishing apps on the Google Play Store starting August 2026. The build system and platform jar files have been upgraded to support Android API level 36.1. The Application Uses Permissions options page now includes the new permissions for the latest API level, and the version of the JetPack Core library the FireMonkey framework depends on for Android has been upgraded. RAD Studio also adds official support for iOS 26, and has increased the default value of the Minimum iOS version supported.
Bookmarks Addon Integrated in the IDE
Expanded built-in source bookmark capabilities
RAD Studio 13.1 fully integrates the Bookmarks Addon into the IDE. The Bookmarks plugin now fully replaces the corresponding IDE's built-in bookmarks functionality. The extended Bookmarks feature adds several advanced capabilities, including automatic bookmark numbering, rapid keyboard-driven navigation, and a structured list of active bookmarks with exact code-line references. This enables developers to move more quickly through their application's source code and quickly return to a previous section of their code.
Windows 11 Specific VCL Styles (also for the IDE)
Easily modernize the look and feel of your Windows applications
RAD Studio 13.1 Florence adds a family of 6 new Windows 11 specific VCL styles, which include different color tones. The list includes: Windows Modern, Windows Modern Dark, Windows Modern SlateGray, Windows Modern Green, Windows Modern Blue, and Windows Modern Purple. There is also a matching new version of the IDE styles, further aligning the RAD Studio IDE to the Windows 11 UI style. There is also support for rounded edges in many windows, an enhanced IDE search control and navigation toolbar.
Faster, more flexible and modern UI styling
RAD Studio 13.1 includes the initial release of a completely new FireMonkey Style Designer, specifically intended for FireMonkey and based on modern design principles. The FireMonkey Style Designer is a standalone application that provides a design-centric interface for working with colors, backgrounds, typography, and interaction states. The Style Designer is built with FireMonkey, and is meant to be used by developers, and by graphic UI designers working alongside the development team.
DelphiLSP LSIF
Faster navigation in library source code
Delphi 13.1 introduces a new extended architecture for the DelphiLSP code completion and code navigation engine. The Delphi Language Server Protocol (LSP) engine now includes support for the Language Server Index Format (LSIF). This reduces dependence on the compiler, improving the performance, stability, and accuracy of Code Insight. This results in much faster performance when serving common navigation requests, without invoking the compiler.
Quality Improvements: C++Builder / Modern Win64
Following the upgrade to Clang 20 and C++23 in 13.0, 13.1 is primarily focused on improving quality across the C++Builder 64-bit Modern compiler toolchain. The clang-scan-deps utility provides faster dependency scanning and enhanced Unicode path handling for linker invocations. For the Windows SDK, the import algorithm is more reliable when multiple SDK versions are installed, and support for the latest Windows SDK has been added. Several issues related to C++ use of the Delphi runtime have also been resolved.
Quality Improvements: IDE and Debugger
RAD Studio 13.1 delivers a major improvement to the HighDPI design experience. Forms can be saved at 96 DPI, useful for teams working on the same project across different resolutions and HighDPI IDE configurations. Product registration has been modernized: the License Manager application and the Product Registration dialog box have been improved, offering HighDPI support via the Per Monitor v2 configuration, updated fonts, and an overall UI cleanup. This release also includes several debugger quality improvements, with a particular focus on the 64-bit debuggers for Delphi and Modern C++.
Quality Enhancements for VCL and FireMonkey
RAD Studio 13.1 includes a large number of quality improvements to UI libraries, VCL and FireMonkey. FireMonkey adds support for Tinted Glyph, which supports recoloring icons in an ImageList, matching a feature already available for the TSpeedButton control. It also adds support for Linux styles and views in the IDE designer, support for DirectX texture filtering, and improvements to the way a TFrame embedded in a FireMonkey form is aligned and manages its margins.
FireDAC and Database
Database access is a foundation of RAD Studio. The FireDAC database library is updated regularly to support new database releases. RAD Studio 13.1 adds support for SAP ASE Server version 16.1, IBM DB2 12.1, and MariaDB Server 12.1 (some database drivers are available in the Enterprise version only). In addition, the legacy SQLite encryption has also been made available for 64-bit Windows applications.
Web Tooling
RAD Studio 13.1 introduces support for HTTP Server-Sent Events (SSE) model, both for Web servers and Web clients, with new classes like TWebResponseStream and THTTPEvent and THTTPEventSource. This enables implementing apps requiring the SSE structure, notably including the MCP protocols. In addition, WebBroker adds Apache configuration support to C++Builder and RAD Server Lite now offers integrated support for TLS 1.3.
RAD Studiois the fastest way to develop cross-platform native apps with flexible cloud services and broad IoT connectivity using Delphi or C++. RAD Studio provides powerful VCL controls for Windows 10 and enables FMX development for Windows, Mac and Mobile. RAD Studio supports Delphi or C++ with a wide array of services for Enterprise Strong Development.
64-bit IDE for 64-bit Windows, New Ternary Operator for Delphi, Initial Support for C++23, IDE Search, AI Component Pack and AI Companion Website, WebStencils Upgrade, GetIt Package Versioning, Quality Improvements to VCL, FMX, IDE, Debugger, RAD Server, Delphi & C++ Code Tooling
Embarcadero Technologies, Inc.builds tools that solve productivity problems for application developers. The company's products allow users to design, build, and run applications from a single code base across all platforms. Ninety of the Fortune 100 companies and a community of more than three million C++ and Delphi users worldwide rely on Embarcadero's award-winning products to deliver critical enterprise applications. Embarcadero is a division of Idera, Inc.
Owner:Embarcadero Technologies, Inc.
Product Name:RAD Studio
Version:13.1 Florence Architect (37.0.59082.6021 RTM Update 1)
Supported Architectures:x64
Website Home Page :www.embarcadero.com
Languages Supported:english
System Requirements:Windows *
ejis7.Embarcadero-RAD-Studio-13-1-Florence.part1.rar.html
ejis7.Embarcadero-RAD-Studio-13-1-Florence.part2.rar.html
ejis7.Embarcadero-RAD-Studio-13-1-Florence.part3.rar.html
