05 de Abril de 2026, 19:41 *
Autor Tema: Hex Editor Neo 7.50.05.9245  (Leído 10 veces)
« : 30 de Marzo de 2026, 02:14 »
Free Download Hex Editor Neo 7.50.05.9245 | 21.3 Mb
Hex Editor Neo is a binary files editing software utility for Windows. It's rich and handy set of features will help all software and hardware developers working with ASCII, hex, decimal, float, double and binary data.
Highly optimized performance, carefully tuned user interface among with new level of application stability will save a lot of your time, money and precious nerves while working with binary files.
Make patches with just two mouse clicks; manipulate your EXE, DLL, DAT, AVI, MP3, JPG files with unlimited undo/redo. Taste the visual operation history with branching.
Features: Editing Files of ANY Size; Built-In Explorer; Unlimited Undo/Redo; Multiple Selection; Selection Save and Load; Find All; Replace All; History Browsing; History Save and Load; Patch Creation; Clipboard Operations; Bytes, Words, Double Words, Quad Words, Floats and Doubles Edit Mode; Pattern Coloring; Data Inspector; Bookmarks; Base Converter; Advanced copy & export; Encodings.
Hexeditor is highly optimized to quickly perform the requested actions. It also allows you to continue working with a document while application is busy performing lengthy operation on another opened document. We take special care about extreme performance while developing tools for you and your convenience.
Opening and efficient handling of huge files
During hex editor program development we focused on its performance and reliability, so the product is based on the most advanced and efficient data processing algorithms. We have created an absolutely unique data editing software, which is able to successfully handle files of ANY size and has absolutely no analogues in this regard. Thus, any extra large file supported by the underlying file system (FAT, FAT32, NTFS) is automatically supported by our product.
Instant data processing regardless of size
Thanks to the use of highly efficient algorithms, hardware acceleration and extensive use of multi-threading technology, the product always remains responsive and quickly performs all binary data editing and file modification operations (including basic I/O, search, replace and clipboard operations) with data blocks of unlimited size. Thus, only using our hex editing software you avoid situations when you lose all modifications due to unpredictably long data processing operations.
Basic file editing features
Using this binary file editing software, you can perform most manipulations with the file data. You can type data, write data to file (direct hex file modification), select data, remove selections, insert data into file, delete binary data from file, insert another file, fill selection with raw hex data patterns, save/load files. It supports overwrite/insert writing modes and allows you to use clipboard: cut, copy/paste, merge data. Modified data is highlighted. You can use 'goto offset' command or make quick address bookmarks for easy navigation.
OS: Windows XP, Vista, 7/8/10/11 and Server 2003 - 2022
CPU: Dual-core x86, x64 compatible
Memory: 2 GB
Storage: 30 MB
https://www.hhdsoftware.com/
Visit All My News
vld7b.Hex.Editor.Neo.7.50.05.9245.zip.html
