05 de Abril de 2026, 17:17 *
Autor Tema: VovSoft Search Text in Files 5.3  (Leído 13 veces)
« : 01 de Abril de 2026, 13:15 »
Free Download VovSoft Search Text in Files 5.3 | 7.2 Mb
Vovsoft Search Text In Files is an easy-to-use file search application for power users. Search through text files using simple queries and the application will quickly list the requested files.
Select directory, enter "Filename Filter" and "Find Text", then click the "Start" button. All files that meet the specified criteria will be listed. You can open, rename, copy or delete the resulting files by right-clicking. You can export the results into TXT or CSV file. You can also display ✅File Size, and file icons using the settings. If you want to ignore files that contain a specified text, you can do this by utilizing the "Ignore Text" option.
Operation file support
You can save the current state of application as operation file and use it later. All you have to do is open an existing operation file, the program will recognize the search criteria and start searching again.
Wildcard support
The application supports filename wildcards; asterisks (*) and question marks (?). An asterisk matches any number of characters, a question mark matches a single arbitrary character.
Operating System:Windows 11/10/8.1/8/7/Vista/XP (32-bit and 64-bit)
https://vovsoft.com/
x7vyn.VovSoft.Search.Text.in.Files.5.3.rar.html
