05 de Abril de 2026, 16:55 *
Autor Tema: Autodesk Vault 2026.1 Products Win x64 English  (Leído 71 veces)
« : 30 de Julio de 2025, 16:10 »
Free Download Autodesk Vault 2026.1 Products | 769.2 mb
Autodeskhas releasedVault 2026.1 Products. This release of Vault delivers enhancements requested by you and the Vault user community, enabling you to accelerate overall design creation and data management experience significantly.
Owner:Autodesk Inc.
Product Name:Vault Client & Vault Server
Version:2026.1 Update
Supported Architectures:x64
Website Home Page :www.autodesk.com
Languages Supported:english
System Requirements:Windows *
Software Prerequisites:pre-installed Autodesk Vault 2026.0 Products and above
What's new Vault 2026.1 Products
Explore the new capabilities and enhancements introduced in this release, which enhance workflow efficiencies.
Workflow Enhancements (What's New in 2026.1)
Copy Design - Property Editing
Unlock a more intelligent and streamlined design workflow with the Vault 2026.1 Update. This enhanced Copy Design feature now empowers users to edit key properties during the copying process, thereby eliminating the risk of missed updates and conserving valuable time. Whether one is duplicating a drawing, a complete design structure, or individual components, it is now possible to modify multiple properties simultaneously, utilizing intuitive copy/paste functionality or directly from Excel. Initiate your next design with confidence, precision, and efficiency right from the moment of copying.
Close
Copy Design - Numbering Scheme
Eliminate Renaming Headaches with Default Numbering Distribution
Vault 2026.1 streamlines the Copy Design process by enabling administrators to establish and disseminate a default numbering scheme for all users. This improvement guarantees consistency from the outset, thus averting expensive renaming tasks and diminishing errors that may arise from improper numbering or naming conventions. By standardizing the nomenclature of new designs, teams conserve time, remain aligned with corporate standards, and ensure that projects progress without disruption.
Close
Update Properties Enhancement
Vault 2026.1 eliminates the inconvenience associated with manual property updates through the introduction of a new, intelligent prompt during file check-out from the Vault client. When users initiate the check-out of a file within the Vault client, they are promptly reminded to update the mapped properties, thereby ensuring data synchronization without necessitating additional steps. This straightforward automation mitigates errors, conserves time, and maintains alignment between designs and Vault data. Though it represents a minor alteration, it possesses a substantial effect on overall productivity.
xAutodesk Vault 2026.1 Products
Close
Batch Description Enhancement
Batch Description Smarter - From 40 Clicks to Just 3
Vault 2026.1 brings a revolutionary advancement to batch Descriptionting through a markedly simplified workflow. Instead of navigating through a cumbersome process involving 40 manual clicks, users are now able to generate comprehensive drawing lists in merely three clicks by utilizing the new "Description Related Design Representation Files" command. By selecting the top-level assembly, Vault systematically compiles all pertinent design representation files, which are then prepared for batch Descriptionting. This enhancement not only saves time but also diminishes errors, thereby allowing your teams to concentrate on design rather than file preparation.
Close
Layout View Enhancement
Bigger Thumbnails, Faster Decisions
Vault 2026.1 enhances the viewing experience by introducing resizable thumbnails in the Vault grid, allowing for easier differentiation between similar models and drawings at a glance. Users are no longer required to open files individually to locate the correct one. This update substantially decreases the number of clicks necessary, streamlining workflow processes and increasing productivity. With improved visuals and reduced procedural steps, users will spend less time searching and more time focused on delivering results.
Close
PDF Automatic Item Attachment
Vault 2026.1 significantly enhances operational efficiency through the automation of attaching 2D PDF files during the Assign/Update Item process. The previous manual steps and the possibility of overlooked files have been eliminated; PDFs are now seamlessly integrated with Items, akin to DWG and IDW representations. This improvement guarantees the inclusion of essential documentation, thereby mitigating the risk of oversight and expediting transitions to downstream teams. Stakeholders can now allocate less time to file management and focus more on design efforts.
Connectivity Enhancements (What's New in 2026.1)
Connect Vault to Fusion Manage Seamlessly and Efficiently with the new Vault Connector
Vault Connector
Vault 2026.1 introduces the Vault Connector, a native, out-of-the-box (OOTB) connector that bridges the gap between design data management and process management systems. The Vault Connector is a powerful new integration that connects Autodesk Vault Professional (PDM) with Fusion Manage (PLM). This solution streamlines enterprise workflows by automating item and BOM synchronization, attaching neutral format files, and mapping attributes between systems. With built-in user notifications, configurable data flows, and support for multiple Vaults within a single Fusion Manage tenant, teams save hours of manual effort and avoid costly errors. From editing Items to creating BOMs, every step is faster, wiser, and fully connected.
Close
Collaboration Enhancements (What's New in 2026.1)
Explore the new capabilities and enhancements introduced in this release, which enhance collaboration.
Viewer Document Navigation
Navigate Multi-Sheet Drawings 30% Faster in the Vault Viewer.
Vault 2026.1 introduces robust new navigation buttons in the integrated viewer for both thick and thin clients, designed to significantly expedite the review process. Users can now traverse multi-sheet drawings in the Autodesk Viewer with ease-eliminating the need for repetitive clicking or the search for the appropriate page. This intuitive enhancement enhances productivity by up to 30%, allowing teams to review documentation more expeditiously and make informed decisions with assurance. Regardless of whether one is involved in engineering, manufacturing, or quality control, improved navigation translates to accelerated progress.
Close
Thin Client Enhancements
Resize, Remember, and Review Faster in the Vault Thin Client
Vault 2026.1 presents a more innovative and efficient approach to managing file properties within the Thin Client environment. The introduction of a resizable property panel, accompanied by persistent panel settings, allows users to instantly view extended property values without the necessity to hover or scroll. This advancement not only conserves time but also mitigates frustration. Furthermore, enhanced caching substantially decreases load times when handling large assemblies, facilitating the revisitation of files without unnecessary waiting periods. The overall experience is quicker and more seamless, allowing users to concentrate on making decisions rather than encountering delays.
Close
API
- Resolved an issue where a popup error was encountered when using the IExplorerUtil.UpdateFileProperties from within the job processor extension. PDM-46983
Add-ins: ACAD
- Resolved an issue where the AutoCAD Vault Add-in appeared blank, when the registry key for ACAD RoamableRootFolder was set to a UNC path. PDM-44946
- Resolved an issue where users were unable to log in to the Vault Add-in for AutoCAD, when AutoCAD is updated to 2026.0.1. PDM-46985
- Resolved an issue where a fatal error was caused by missing modeler DLLs when creating DWF, editing, or renaming DWG files checked into Vault 2026.0.1. PDM-47018
Add-ins: Inventor
- Resolved an issue where the sequence numbering scheme was skipped when using the copy option in Inventor with Vault. PDM-43767
- Improved stability by addressing an issue where Inventor crashed to desktop without generating a CER when scrolling with the Vault add-in. PDM-44697
- Resolved an issue where the "Open Drawing from Vault" function did not work in the Inventor Model Browser. PDM-45519
- Resolved an issue where opening an assembly from Vault in Inventor caused the Inventor Vault Browser to display a yellow exclamation mark for all files. PDM-46520
- Resolved an issue where the error message "This method is not supported by current server configuration" appeared when opening a drawing from Vault in Inventor with Vault Basic. PDM-46745
- Improved stability by addressing an issue where a crash occurred when placing the iAssembly from Vault and selecting a different configuration from the table. PDM-46941
- Resolved an issue where the error message "Unhandled exception.. Object is currently in use elsewhere" appeared when switching views in the "Open from Vault" dialog in Inventor. PDM-47044 PDM-47587
Batch Description
- Resolved an issue where the "Border" custom watermark was missing or incorrectly positioned when Descriptionting in Vault Client. PDM-46175
- Resolved an issue where the thumbnail was missing for Inventor drawings in Vault Description. PDM-46233
Change Order
- Improved stability by resolving an issue where a hang occurred when selecting the "Files" tab for specific change orders. PDM-45830
Client
- Resolved an issue where PDFs created using the DWG to PDF.pc3 Descriptionter with Batch Printing had incorrect orientation and poor quality. PDM-27522
- Improved stability by addressing an issue where Inventor crashed when thumbnails were enabled in the Open/Place from Vault dialog in Vault Basic. PDM-45112
- Resolved an issue where a predefined list in a numbering scheme containing a description could not be pasted to other items when the item number was changed using that scheme. PDM-45615
- Resolved an issue where Vault Pack and Go created and attached .v files to emails. PDM-46101
- Resolved an issue where enabling the "Include Parent Versions" option had no effect on the results displayed in the "Where Used" tab. PDM-46276
- Resolved the issue with using persistent ID in thin client URL was leading to error. PDM-46321
- Resolved the issue where a 'View' created for a 'Saved Search' was not distributed. Previously views were distributed only for Folder type saved search. PDM-46646
- Resolved an issue where the Autodesk CER component dialog failed to load in Vault Client 2026. PDM-47014
- Resolved an issue where Advanced Find was not localized in any language pack for Vault. PDM-47714
Copy Design
- Resolved an issue where "Select from Vault" did not save the last used folder if called from Copy Design. PDM-45799
- Resolved an issue where copying a design started on an IDW was adding the subfolder names additionally. PDM-46081
Data Standards
- Resolved an issue where the Vault help documentation links for downloading Data Standard tutorial files and video documentation were broken. PDM-46268
Help / Documentation
- Resolved an issue where the link to download the "Autodesk Vault server - Content Center libraries" in the help documentation was incorrect. PDM-43223
- Resolved an issue where the help documentation for the category assignment rule condition mentioned "Pick a date" instead of "Date condition." PDM-43743
- Added a "Troubleshooting with Vault Client Diagnostic Log Files" section to the help documentation. PDM-45711
- Resolved an issue in help-documentation regarding the Workspace Sync. PDM-47070
Items
- Resolved an issue where the incorrect quantity was displayed in the item BOM. PDM-45455
- Resolved an issue where the AutoCAD Mechanical custom BOM property with a value of 1.5 was passed to Vault as 1500. PDM-45499
- Resolved an issue where, after resolving the search index, the customer encountered errors 109 and 1388 when updating an item. PDM-45967
- Resolved an issue where assigning or updating an item ignored decimal digits (comma) in German environments. PDM-46335
- Resolved an issue where the "Assign/Update item" function worked differently, and updating an item with removed associated files resulted in Error 1405. PDM-46864
- Resolved an issue where Vault Item BOM Export included unchecked positions if they were used in multiple places in the currently exported BOM. PDM-47302
Job Processor
- Resolved an issue where the job failed with the error "Object reference not set to an instance of an object" when using "Download from Cloud Drive" in Project Sync. PDM-42659
- Resolved an issue where the Vault Job Processor created broken project file shortcuts when generating DWFs. PDM-45161
- Resolved an issue where updating the visualization (DWF) file for an older version of an Inventor drawing caused it to incorrectly reference the latest model version instead of the corresponding historical version. PDM-46067
- Resolved an issue where the command line argument "[argument]" required an already started Job Processor when managing Vault 2026 Job Processor from the command line. PDM-46861
Server
- Resolved an issue where there was no check for enabling replication with different collation, which caused failure to disable replication and create a backup. PDM-42614
- Resolved the issue where 'Backup only for databases' checks for filestore permissions, causing delay for the backup operation. PDM-45189
- Resolved an issue where a database 109 error occurred when transitioning an ECO with over 6,000 records attached to it. PDM-45829
- Resolved an issue where replication stopped working and was unable to reinitialize after updating to CU29. PDM-46958
- Resolved an issue where search index was very slow when archived files are present. PDM-47061
Thin Client
- Resolved the issue with download operation in thin client, where files were getting collected incorrectly. PDM-46322
- Resolved an issue where no item was shown in the Item and Where Used tabs in Vault Thin Client when a file was attached to an item. PDM-46411
Viewer
- Resolved an issue where Inventor in read-only mode did not take the reference when viewing in window on a historical drawing. PDM-42116
Autodesk Vaultdata management software, part of the Autodesk solution for Digital Prototyping, helps you organize, manage, and track design, engineering, and simulation data and documentation. Get more control over your designs with revision management capabilities and quickly find and reuse data for better management of your design and engineering projects. Whether your team sits in the same office or across multiple sites, Autodesk Vault helps you collaborate more effectively and share information with other departments, maximizing your design data value.
What's New in Vault 2026 | Full Feature Breakdown
This in-depth walkthrough covers the latest enhancements designed to streamline data management, improve team collaboration, and simplify everyday tasks.
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Fileaxa
c0v6rtfwvq5s
Uploady
wprct.Autodesk.Vault.2026.1.Products.rar
wprct.Autodesk.Vault.2026.1.Products.rar.html
https://turbobit.net/27dt1rhzpcs6/wprct.Autodesk.Vault.2026.1.Products.rar.html
