05 de Abril de 2026, 16:55 *
Autor Tema: Super Ear - Improve Hearing v58.0  (Leído 25 veces)
« : 04 de Agosto de 2025, 19:42 »
Free Download Super Ear - Improve Hearing v58.0 | Android | 10.1 MB
Premium version
Looking for sound amplifier app to listen sound clear? Super Ear - Improve Hearing app is the perfect solution for your hearing amplifier.
Super Ear - Improve Hearing app is a tool that amplifies the voice and boosts sound to hear clearer and louder. It also boosts voice directly into your ears and improves hearing by making sound audible and clear.
This voice enhancer app can turn your device into a listening device and powerful sound amplifier. You can listen to whatever you want to hear clear from a distance by a hearing amplifier.
How does this app work?
- The super ear - sound amplifier app amplifies the sound from the phone's microphone, earphones, or Bluetooth headphones and gives clear sound in output. This hearing amplifier amplify frequencies of sound to give clear sound in the output.
How can we evaluate our listening ability(through frequencies of sound)?
1. Go to a silent place and connect earphones for a better experience. (You can also use the Bluetooth headphones to amplify the sound)
2. Press 'Start' to start the test.
3. Press 'I Can Hear' when the sound is audible.
4. Press 'I Can't Hear' when the sound is not audible.
5. After the hearing test process is completed, you can check your result.
If you are in the lecture and sitting in the back and won't able to hear the lecturer, then this Super Ear app can be used as a sound amplifier to clear hearing and loud.
Where this Super Ear - sound amplifier can be used?
- Hear loud and clear lectures, meeting conversations, and interviews from a distance
- Listen to lectures better from back seats
- Clearly hear sound in a crowded area
- Listen to clear TV programs or radio channels from a distance
- Hear amplified surrounding sounds
- Record surroundings sounds or save important voice notes
Using the inbuilt sound booster in the app, you can boost the sound volume to hear louder. You can hear and boost the live sounds.
With the help of an equalizer, you can modify and amplify the voice and hear better. If you wish to lower any unwanted sounds or noises, then with the help of an equalizer you can do it.
Salient Features of Super Ear - hearing amplifier
- The Super Ear app is simple and easy to use.
- Sound record feature.
- Recorded sound will be stored in phone storage.
- Sound booster to hear louder
- Equalizer to amplify and modify sound as desired.
- Hear clear from the distance.
Use this app as a listening device that helps to hear the modified and amplified surrounding sounds. For better results, use the earphones or bluetooth headphones on your device.
Requirements: Android 7.0+
https://play.google.com/store/apps/details?id=com.superear.improvehearing&hl=en
h4eb1.Super.Ear..Improve.Hearing.v58.0.apk.html
