Free Download iZotope FXEQ v1.0.0.442 | 66.3 MbUnlock the color in your sound. 5 powerful creative effects. 1 innovative EQ workflow. Easily add drive, dimension, and texture to your tracks. No more complex routing, buses, and sends - simplify your effects chain with the equivalent of 10 separate plugins in 1. Say hello to brilliant sound without the struggle.
Find your true hues
Electrify your sound with Saturate. Add vintage vibes with Lo-Fi. Shape depth and movement with Chorus, Flanger, Phaser, Reverb, and Delay. Then warp any sound into something totally new with unique combinations and automations.
From beefy bass to crunchy drums to washed-out synths, it's never been easier to infuse creative flair exactly where you need it.
Unique EQ workflow
FXEQ doesn't just "apply" effects. Paint your mix with tone and texture using each module's 6-band EQ. Then tweak with 4 versatile filter shapes and adjustable Q. Forget typical multi-effects. This is a whole new way to sculpt your sound.
Saturation
Give your sound punch, character, and grit with 8 saturation modes. Need subtle warmth on vocals? How about screaming distortion on bass? Go big, small, or anywhere in between.
Lo-fi
Sounding a bit too clean and polished? Missing some analog flavor? Add everything from vintage vibes to bit-crushed chaos with 4 lo-fi modes.
Reverb
Shape your space with 3 reverb types. Dreamy vocals, atmospheric synths, the glue that brings the whole thing together? This way.
Delay
Add dimension and stereo intrigue with 4 delay types. Dial up the groove on drums, play Marco Polo with vocals, give your guitar licks some slapbacks, and beyond.
Modulation
Get things moving with 4 modulation effects. Create lush, layered vocals with Chorus. Send drums swirling with Flanger. Give keys some shimmer with Phaser. And beef up guitar solos with Doubler.
Pro presets and more
Find your starting point fast with over 60 presets - pick your favorite or randomize, then tweak to your taste. Always avoid clipping with the zero-latency Limiter. And, if you want to use FXEQ as a send effect, just enable "FX Only" mode to remove the dry signal and fine-tune further.
https://www.izotope.com/en/products/fxeq
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeUploadytssqu.iZotope.FXEQ.v1.0.0.442.rarRapidgatorhttp://peeplink.in/9c7fda6100eaUploadCloudtssqu.iZotope.FXEQ.v1.0.0.442.rar.htmlFikpertssqu.iZotope.FXEQ.v1.0.0.442.rar.htmlLinks are Interchangeable - No Password - Single Extraction
