06 de Abril de 2026, 22:08 *
Autor Tema: Autodesk 3ds Max 2026.2 Build 28.2.0.20659 by m0nkrus (MULTi/ENG)  (Leído 54 veces)
« : 07 de Agosto de 2025, 18:59 »
Free Download Autodesk 3ds Max 2026.2 Build 28.2.0.20659 by m0nkrus (MULTi/ENG)
Autodesk 3ds Max 2026 is a comprehensive solution for 3D modeling, animation, rendering and compositing, designed to realize the creative potential of game developers, visual effects and graphics, as well as other specialists in this field. The program will be useful for developing models, scenes, animation, materials and everything related to the world of 3D. All special effects in films, presentations of new models of equipment, clothing, cars - all these are pre-developed three-dimensional models, which are then transformed into real objects.
Autodesk 3ds Max is used by artists and visual effects professionals in the film and television industry, as well as game developers and designers to create virtual reality games. The program can also be used for building, infrastructure, and construction design, product development, and production planning. In addition, Autodesk 3ds Max helps users create massive game worlds, detailed characters, customize building environments, create scenes with many people, and simulate the physical properties of liquids such as water, oil, and lava.
Key features of 3D Studio Max :
• Polygon, spline, and non-uniform rational B-spline (NURBS) modeling capabilities enable efficient creation of parametric and organic objects.
• The Graphite modeling toolset, with over 100 polygon modeling and 3D freeform creation tools, opens up the creative possibilities.
• ProOptimizer technology provides high precision control of edges and points of the modeled object. The number of selected objects can be reduced by up to 75 percent without reducing detail.
• Mesh smoothing and subdivision surface tools allow you to fine-tune fine details and optimize meshes for interactive manipulation and rendering.
• Creative texture manipulation capabilities including tiling, mirroring, decals, blurring, splinting, UV stretching, dewarping, UV fixing, UV template export, and more.
• Slate's Material Editor lets you model shading of any complexity using extensive libraries of textures, images, material samples, and procedural textures.
• The render to texture feature allows you to "bake" the material and lighting parameters of each object into new texture maps.
• Animation - Advanced tools help you create intelligent, believable characters and produce high-quality animation:
• Character Animation Toolkit (CAT), bipedal creature and crowd animation tools allow for efficient procedural animation and rigging.
• Skin and CAT Muscle modifiers allow precise and smooth control of skeletal deformation when moving bones.
• You can rig complex machines and characters with custom skeletons using 3ds Max bones, inverse kinematics (IK) solvers, and custom rigging tools.
• Combining one- or two-way relationships between controllers allows you to create simplified animation interfaces.
• CAT, Biped and 3ds Max objects can be animated using layers, allowing you to work with very dense motion capture data without breaking keyframes.
• Built-in clothing modeling module allows you to transform almost any 3D object into clothing, as well as create clothing items from scratch. They can then be modified and animated.
• You can apply fur, hair, and other strand-based effects (like grass) and control their stylization and animation with great precision.
• You can develop complex event-driven particle effects (such as water, fire, splashes, or snow) and control them using expressions, scripts, and direct manipulation.
• Rendering - Powerful 3D rendering capabilities help you get stunning quality images in less time:
• You can produce high-quality pre-visualization, animation, and marketing materials using the innovative, high-performance Quicksilver renderer.
• The mental ray® renderer lets you quickly set up photorealistic lighting and custom shaders.
• Unlimited batch rendering capabilities in mental ray allow you to efficiently use network resources and render faster.
• The Reveal™ system allows you to visualize specific areas both in the viewport and in the frame buffer.
• Simultaneously output the results of multiple render passes, including high dynamic range (HDR) images from architectural and design materials, into the 3ds Max® Composite module.
• Workflow integration - Import data from multiple sources and seamlessly transfer Autodesk 3ds Max and Autodesk 3ds Max Design data across files, applications, users, and workstations:
• Autodesk® FBX® technology enables data exchange with leading 3D applications, including Autodesk® Maya®, a 3D animation, modeling, visual effects, rendering and compositing program; Autodesk® Mudbox™, a 3D digital sculpting and texture painting program; and Autodesk® Revit® Architecture, a building design program.
• Non-destructive file linking procedures allow you to efficiently work with changes to original design data created in Autodesk applications that support FBX export.
• Import solids data from Autodesk® Inventor® 3D CAD software directly into Autodesk 3ds Max and Autodesk 3ds Max Design.
·Ability to merge data from over 30 2D and 3D formats including 3ds, AI, DEM, XML, DDF, DWG, DXF, FBX, DAE, IGES, IPT, IAM, OBJ, STL, VRML, FLT, SAT and SKP.
• You can improve scene performance and reduce memory consumption by temporarily unloading containers from the viewport while maintaining their relationship with the scene and loading them back as needed.
• You can move, delete, copy and save container nodes.
• You can use containers to override object properties when organizing a scene without affecting the layer organization (similar to working with nested layers).
The ability to link containers created by different users into a single scene, as well as modify containers created by other users, makes collaboration more flexible and prevents unauthorized changes.
New Features in 3ds Max 2026
-  Default material: OpenPBR
OpenPBR is the new default material in 3ds Max 2026.
-  Support for Vertex Weld modifier for Spline objects
The updated Vertex Weld modifier now supports Spline objects in addition to Mesh objects.
-  Return to stack position
Use the new Preserve Stack Position switch to revert to the modifier you had selected on the object before you selected the new object.
-  Create panel: search for objects
Easier searching for objects in the Create section of the Command panel.
-  Performance improvements
Array Modifier, Boolean Modifier, Conform Modifier, Displacement Modifier and Max Fluids have been optimized for faster processing.
-  Animation update
Exciting performance improvements to the viewport, CAT and Biped workflows.
-  New OSL maps
Three new maps are now available for Open Shading Language (OSL).
-  Create a rectangle using three points
Added a new method when creating Spline Rectangle objects that allows you to create objects at angles other than right angles aligned with the world axis.
-  Retopology for 3ds Max
Improved processing times with updates to the underlying ReForm algorithm in Retopology Tools v1.6 and increased the number of Flow Retopology jobs to 50 per month.
-  USD for 3ds Max 0.10
USD for 3ds Max 0.10 introduces a layer editor that allows you to easily manage USD layers.
-  Arnold for 3ds Max 5.8.0
3ds Max 2026 includes Arnold version 5.8.0.
- Substance 3.0.5
Substance for 3ds Max has been updated to version 3.0.5.
List of changes made
What was changed by the author of the assembly :
- The assembly is based on the official distribution of Autodesk 3ds Max 2026.2.
- The installation package now includes the option to opt out of installing the Advanced Modeling Tools for 3ds Max 2026 module.
- The installation package now includes the option to opt out of installing the Retopology Tools for 3ds Max 2026 module.
- The installation package now includes the option to opt out of installing the Flow Retopology for 3ds Max 2026 module.
- The installation package now includes the option to opt out of installing the MAXtoA for 3ds Max 2026 module.
- The option to refuse installation of the USD for 3ds Max 2026 module has been added to the installation package.
- The option to refuse installation of the Autodesk CER Service module has been added to the installation package.
- The Autodesk Access module has been excluded from the installation process. The option to install it manually has been left.
- The Autodesk Access Service Host service will be disabled in the program installed from the assembly.
- The Autodesk Identity Manager module has been removed from the installation package.
- The Autodesk Genuine Service module has been removed from the installation package.
- The Autodesk 3ds Max 2026 SDK module has been removed from the installation package.
- The Autodesk Network License Manager module has been removed from the installation package.
- The automatic update mechanism for the Autodesk Licensing module has been disabled.
- Everything you need to cure the program is inside the image in the Crack folder.
Treatment procedure
• Install Autodesk 3ds Max 2026 (Setup.exe file).
• Run the AdskNLM.exe file from the Crack folder and just wait for the message "Cracking complete. Enjoy!" to appear.
• Run the installed application. In the window for selecting the license type, click Use a network license.
• Enjoy the registered version of the product!
System requirements :
• 64-bit version of Windows 10 (version 1809 or later) or Windows 11
• 64-bit multi-core Intel or AMD processor with support for the SSE 4.2 instruction set
• 4GB RAM (8GB or more recommended)
• A detailed list of recommended systems and video adapters is provided in the article "Hardware certified for 3ds Max"
• 9 GB of free disk space for installation
• To access online content, the latest version of one of the following browsers: Microsoft Edge, Google Chrome, Microsoft Internet Explorer, Mozilla Firefox
• Three-button mouse
Whats New in Autodesk 3ds Max
https://help.autodesk.com/view/3DSMAX/2026/ENU/?guid=GUID-5E7810B6-59DF-434E-AB24-BC2A452C715C
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10 (64-bit only)
Interface language: English / Deutsch / Francais / Portuguese / Japanese / Chinese / Korean
Cure: AdskNLM Crack
File size: 5.36 GB
Autodesk.3ds.Max.2026.2.part1.rar.html
Autodesk.3ds.Max.2026.2.part2.rar.html
Autodesk.3ds.Max.2026.2.part3.rar.html
Autodesk.3ds.Max.2026.2.part4.rar.html
Autodesk.3ds.Max.2026.2.part5.rar.html
Autodesk.3ds.Max.2026.2.part6.rar.html
