06 de Abril de 2026, 00:22 *
Autor Tema: Cypheros TS-Doctor 4.2.15 Multilingual  (Leído 26 veces)
Conectado Conectado
« : 11 de Agosto de 2025, 22:44 »
Free Download Cypheros TS-Doctor 4.2.15 Multilingual Fast Links | 75.7 Mb
Create your own movie library, easy, quick and without loss of picture and sound quality. The TS-Doctor is the perfect tool for editing and repair of recordings from Sat-, Cable and DVB-T Receivers.
Features
Working with transport streams can be very difficult. Many standard video editors fail to process this kind of files correctly. You can get asynchronous audio and video, the playback stops, judders or the playback is not possible at all. This is where TS-Doctor comes to rescue.
TS-Doctor can do this better, faster and without loss of quality.
New features of version 4.0
The new multilingual setup contains the 32bit and 64bit version of the TS-Doctor and is very easy to install.
TS-Doctor 4.0 now offers the full power of a true 64bit application.
The new audio analysis helps to detect annoying commercial breaks.
Smart Data Analysis
On opening a TV recording, the TS-Doctor starts a quick deep transport stream analysis to get as much information as possible about the structure, the included streams and the meta data.
This way nearly any transport stream format current recording devices uses, can be read, be it TS, MTS, M2TS, DVR, TS4, TRP, REC, STR or another related format.
It tries to identify the source and the exact format of the recording, a program guide and the best methods to fix problems and detect commercial breaks. Most set top boxes record much more than only one video and one audio stream.
Commercial detection
TS-Doctor makes use of this additional information and helps you to remove annoying commercial breaks and garbage data, fix stream problems and brings the recording into shape for your video library and better compatibility with today's media players.
Meta Data
It extracts program guide information if possible and saves it along with the new cut file, so you know exactly what movie or episode you recorded.
Complete details for your video library.
Video Editing
TS-Doctor includes an easy-to-use video editor window to check or improve the result of the automatic cutting or allow for manually cutting. The simple, fast and lossless cutting of the TS-Doctor can be used even for recordings of camcorders, if the recorder format is TS, MTS or M2TS. This is the case for example for many models from Sony, Canon and Panasonic.
DVB Subtitel Converting
Conversion of DVB subtitles into the more widely-used SRT text format. This makes TS Doctor one of the few programs that can convert DVB subtitles, including the colour information, into a text format.
Error Checking
The result page gives you a detailed overview about the amount of removed data and errors found during the processing. Even the streams are inspected in deep, TS-Doctor is lightning fast.
Extended error checking guarantees perfect results.
Useful Expert Tools
TS-Doctor includes many useful tools to work with transport streams. With these tools you can merge, filter, demux, remux streams or even use the TS Packet Viewer to inspect transport streams on packet level.
TS-Doctor is the swiss army knife for transport streams.
Operating System:Windows 7, 8, 10 and 11
Home Page-http://www.cypheros.de/eng/tsdoc4.html
sr2ko.Cypheros.TSDoctor.4.2.15.Multilingual.rar.html
