05 de Abril de 2026, 16:26 *
Autor Tema: Blue Cat Audio Fader Hub v1.21  (Leído 26 veces)
« : 13 de Agosto de 2025, 00:45 »
Free Download Blue Cat Audio Fader Hub v1.21 | 59.5 Mb
Blue Cat's Fader Hub is a network mixing and streaming software that provides an easy solution to play and record with other musicians on a local network or thru the Internet in real time.
Join the LLAN party! Connect your instrument and play with other musicians over the Low Latency Audio Network (LLAN) thanks to this unique network mixing and streaming console.
Fader Hub features a local mixing console to mix several audio inputs from an audio interface, and a network mixer that can send the local mixdown to other computers over the network, and mix it locally with the audio streams received from them.
It is fully compatible and interoperable with the Connector plug-in. It includes several built-in audio effects and can also load third party VST, Audio Unit and VST3 plug-ins.
Fader Hub can also record the full mix and individual streams to disk, making it easy to record multiple instruments over an IP network.
Thanks to Fader Hub's low latency peer-to-peer connection, every musician with a laptop in a band can easily manage his/her personal headphone mix, while keeping the lowest possible latency for his/her own instrument.
Main Features
Network mixing console: play with other musicians thru a local network or over the Internet.
Multitrack recording: record the full mix or individual tracks on your own machine.
Distributed recording: synchronize playback and recording accross multiple instances over the network, with network latency compensation.
Built-in effect plug-ins (EQ, Compressor, Gate, delays, reverb...).
Load third party VST, vST3 or Audio Unit plug-ins.
Supports multiple sampling rates on a single connection (built-in resampling).
Built-in drift compensation.
Fully compatible with Blue Cat's Connector & Freeceiver.
Connect up to 8 musicians together (and more by loading the plug-in).
Up to 8 local stereo audio inputs (personal mix).
Optional audio compression to reduce the bandwidth (powered by Wavpack).
Blue Cat Audio Standards
Available as a standalone application and in most plug-in formats for Mac and Windows.
Full MIDI control and automation support, MIDI Learn.
No CPU load on idle: processing shuts down when fed with silence (optimal CPU usage).
Customizable user interface with transparency & zoom.
Smooth Bypass: noiseless plug-in activation / deactivation.
Undo/Redo.
Full featured integrated presets manager.
Copy/paste the state of the plug-in between instances.
Any sample rate supported.
https://www.bluecataudio.com/Products/Product_FaderHub/
http://peeplink.in/9d9e45bc56a4
sj6cs.Blue.Cat.Audio.Fader.Hub.v1.21.rar.html
