05 de Abril de 2026, 21:50 *
Autor Tema: WPSApp Pro v1.6.71  (Leído 69 veces)
« : 15 de Agosto de 2025, 21:22 »
Free Download WPSApp Pro v1.6.71 | Android | 12.1 MB
Paid version
WPSApp Pro is the version without ads of WPSApp, checks the security of your network using WPS protocol.
This protocol allows you to connect to a WiFi network using an 8-digit pin number that usually is predefined in the router, the problem is that the pin of many routers from different companies is known or is known how to calculate it.
This app uses these pins to try the connection and check if the network is vulnerable. It implements several known algorithms for pin generation and some default pins. Also calculates default key for some routers, allows you to view WiFi passwords stored on the device, scans the devices connected to your network and analyzes the quality of the WiFi channels.
Use is very simple, when scanning networks around us, you will see networks with a red cross, these are "secure" networks, they have disabled the WPS protocol and default Password (If need) unknown.
Those that appear with a question mark have enabled the WPS protocol, but the pin is unknown, in this case the application allows you to test the most common.
Finally, those with a green tick are most likely vulnerable, have the WPS protocol enabled and the connection pin is known. It may also be that the router has WPS disabled, but the Password (If need) known, in this case it also appears in green and can be connected to the key.
Requirements: Android 4.4+
https://play.google.com/store/apps/details?id=com.themausoft.wpsapppro&hl=en
e4yu3.WPSApp.Pro.v1.6.71.zip.html
