06 de Abril de 2026, 04:22 *
Autor Tema: Wise Folder Hider Pro 5.0.9.239 Multilingual  (Leído 36 veces)
« : 16 de Agosto de 2025, 00:54 »
Free Download Wise Folder Hider Pro 5.0.9.239 Multilingual Fast Links | 7.2 Mb
Hide, encrypt, or lock your personal files, photos, videos, and other important private data on Windows PCs and laptops. Protects against unauthorized reading, writing, renaming, and deletion.
Lock Files
Locks 4 properties of files: Read, Write, Rename, and Delete.
Unlike hidden and encrypted files, a locked file is visible in Windows File Explorer, you can still see it at its original location. However, you CANNOT open it, edit it, change its ✅File Name, move (copy) or delete it.
Encrypt Files & Folders
To encrypt files, you need to create an encrypted partitioned drive first, then drag and drop your files and folders to the encrypted drive. The files and folders will be hidden and encrypted after you close the program. With its great protection, others will NOT be able to Open, Read, Modify, Delete, Move, Copy the encrypted files and folders, or even NOT be able to see them.
Hide Files & Folders
With Wise Folder Hider you can easily hide your files and folders so they disappear from Windows File Explorer. No one can see your hidden files and folders. Effectively protect your private or important data from unauthorized access and deletion.
Hide USB Drives
In many cases, you need to share a USB drive with others and some sensible files will be read by others. With Wise Folder Hider 4, you can hide and password protect your personal file and folders on the USB stick with one click. Even the USB drive is lost, the important files will not be stolen.
Make Encrypted Files Portable
The new version of encryption can let you manage the encrypted files in batches. What's more, the encrypted drive is removable and portable. You can use it just like using a USB drive or even create the encrypted drive directly on the removable drive.
Multiple Layers of Password Protection
When you first use Wise Folder Hider, you need to setup a login password. Inside the program, you can set a second level password for each file, folder, USB drive and encrypted drive. Anyone else can't uninstall the program without login password or delete the protected and encrypted drive without the second level password.
Context Menu Option & Super User-friendly Interface
The interface of Wise Folder Hider is very intuitive. Even a first timer can get the hang of it in a minute. Better yet, while installing this program, an item called Hide File/Folder with Wise Folder Hider is automatically added to the context menu. Users can hide files or folders by right-clicking them without launching Wise Folder Hider.
Operating System:Windows 11, Windows 10, Windows 8, Windows 7
https://www.wisecleaner.com/
qdpml.Wise.Folder.Hider.Pro.5.0.9.239.Multilingual.rar.html
