05 de Abril de 2026, 21:26 *
Autor Tema: Luxion KeyShot Enteprise 2025.2.1 v14.1.1.5 Multilingual (x64)  (Leído 65 veces)
« : 17 de Agosto de 2025, 00:06 »
Free Download Luxion KeyShot Enteprise 2025.2.1 v14.1.1.5  (x64) Multilingual Fast Links | 1.86 GB
KeyShot is designed to make 3D rendering and animation easy. It allows you to apply materials and lighting fast and provides the most accurate materials appearances and real-world lighting, all in a powerful interface that provides advanced capabilities and the ability to see all your changes in real-time. So, what is KeyShot? And what does it help you do?
Focus on your design, not software.
KeyShot is extremely easy to learn and use to achieve photographic results in minutes through a simple, workflow-based interface with all the advanced capabilities for the most experienced 3D render professional.
Present your ideas sooner.
KeyShot brings visual speed and agility to the entire product development process, with the widest 3D file format support for a fluid workflow from concept to final product.
Make it more realistic.
KeyShot materials go beyond physical appearance providing scientifically accurate properties for the highest quality visuals. Use a preset, an exclusive partner material or create your own.
Access complete computing power.
KeyShot gives you the power and the choice to utilize either CPU or NVIDIA GPUs for rendering and the capability to scale linearly for unmatched performance.
Light it up right.
KeyShot provides advanced lighting capabilities that create the most accurate lighting for simple studio shots or the most complex interior lighting.
See your results instantly.
KeyShot is real-time rendering to the core. Not a mode. Not an afterthought. See everything as it happens. Every change from material and lighting to cameras and animation is seen instantly as you work.
Leave them speechless.
From still image and animations to interactive web and mobile content, KeyShot's ability to create the highest quality visuals possible ensures you are using the best tool for all your visualization needs.
KeyShot is designed to run fast on the most basic hardware configurations or the most powerful of systems to take full advantage of all CPU cores available and scale performance linearly. To get started, here are the minimum recommendations and system requirements for the latest version of KeyShot.
Microsoft Windows
- Windows 10 or 11 64-bit
- Windows Server 2016 and above 64-bit
General
- 64-bit platform
- 2GB RAM
- 2GB Disk Space
- Dual core CPU1, 2
- OpenGL 2.0 capable system3
- Intel or AMD 64 bit processor with SSE4.1 or higher
- 1920 x 1080 resolution or higher
https://www.keyshot.com/
dl4su.Luxion.KeyShot.Enteprise.2025.2.1.v14.1.1.5..x64.Multilingual.rar.html
