Free Download Red Gate SmartAssembly 8.3.7.6539 | 14.8 MbSmartAssembly is an obfuscator that helps protect your application against reverse-engineering or modification, by making it difficult for a third-party to access your source code.
If your entire business rests on the IP embodied in your software or you don't want your C# or VB.NET code exposed internationally, then obfuscating your code becomes a necessity, not a luxury.
With SmartAssembly, you get a comprehensive set of obfuscation features, including name mangling, control flow obfuscation, strings encoding, reference dynamic proxy, and declarative obfuscation.
Key features
Name mangling
Changes the names of methods and fields to make it hard to understand their purpose.
Control flow obfuscation
Converts the code inside methods to 'spaghetti code' to make it difficult to see how the application works.
References dynamic proxy
Creates a proxy for calls to methods outside of your assembly to make it hard to find external calls.
Strings encoding
Encodes the strings used in your software to hide such information as passwords and SQL queries.
Resources compression and encryption
Compresses and encrypts managed resources to make them hard to understand, and to reduce the size of the assembly.
Pruning
Removes non-useful metadata to make the code harder to reverse-engineer, reduce the size of the assembly, and improve loading time.
Dependencies merging
Takes all the DLLs and merges dependencies into the main assembly, so you don't have to load lots of DLL files, and so that they can also be obfuscated.
Dependencies compression and embedding
Compresses and embeds your dependencies into your main assembly, simplifying the deployment of your software and reducing the size of your program.
Method parent obfuscation
Moves methods in your code by changing the class they are in, making it harder to understand how methods and classes relate to each other.
Strong name signing with tamper protection
Signs your assembly and helps to protect it against modification (the additional tamper protection is not available in the Standard edition).
Declarative obfuscation
Excludes a member from obfuscation using custom attributes directly in your code.
System requirements:512MB RAM (minimum)
10 MB free hard disk space
Microsoft .NET Framework version 3.5 SP1 Client Profile or above must be installed in order for SmartAssembly to run.
Microsoft .NET Framework version 3.5 SP1 Full Profile or above must be installed in order to install SmartAssembly.
Access to a SQL database - see below for specific requirements.
Supported operating systems
Windows Server 2008
Windows Server 2008 R2
Windows 7
Windows 8
Windows Server 2012 R2
Windows 10
Both 32 and 64-bit operating systems are supported.
Supported SQL Server versions
You must use one of the following versions of SQL Server (SQL Express and SQL LocalDB also work):
SQL Server 2008
SQL Server 2008 R2
SQL Server 2012
SQL Server 2014
SQL Server 2016
https://www.red-gate.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorxiv82.Red.Gate.SmartAssembly.8.3.7.6539.rar.htmlUploadCloudxiv82.Red.Gate.SmartAssembly.8.3.7.6539.rar.htmlFikperxiv82.Red.Gate.SmartAssembly.8.3.7.6539.rar.htmlLinks are Interchangeable - No Password - Single Extraction
