05 de Abril de 2026, 18:01 *
Autor Tema: Foxit PDF Editor Pro 14.0.0.33046 + Portable (MULTi/RUS)  (Leído 38 veces)
« : 19 de Agosto de 2025, 00:39 »
Free Download Foxit PDF Editor Pro 14.0.0.33046 + Portable (MULTi/RUS)
Foxit Foxit PDF Editor Pro 14 is an application for viewing, editing and creating PDF documents. Among the main advantages of the program, the developers point out the short startup time and higher speed of creating PDF documents. With the help of the program, you can also merge and split PDF documents, delete and insert new pages, create electronic forms and notes, convert almost all documents that can be printed on a printer to PDF format, including DOC, PPT, TXT, HTML files and many others.
Program features:
» Faster PDF document creation compared to other PDF utilities
» Small size of the distribution and fast speed of program launch
» Create PDF files from any printable file
» Create PDF document directly from scanner
» Editing and modifying the contents of PDF files
» Compare two PDF files to see if there are any differences between them
» Add, remove or merge pages from multiple PDF files
» Creation and filling of electronic forms
» Protect PDF documents with passwords and certificates
» Adding digital signatures to PDF documents
Key Features:
Speed and quality:
• Create PDF documents three times faster!
• Quick program launch.
• The appearance and content of the created PDF files fully correspond to the source materials.
Industrial quality PDF documents:
• Support for over 200 of the most common Office file types.
• Simultaneous work with several documents.
• Quick access button on the Microsoft Office toolbar.
• PDF/A support.
• The ability to choose PDF 1.3 or 1.7 specifications will make your PDF document compatible with different PDF viewers.
Hiding important data:
• You can hide sensitive information (text and images) in a PDF document, such as your Social Security number.
Microsoft Active Directory Rights Management Service Protector and Policy Manager:
• Enhanced document management capabilities through integration with Microsoft Windows Server Active Directory Rights Management.
• Control access to each PDF file, distribute rights to read and change documents.
XFA form filling:
• XFA (XML Forms Architecture) support for filling forms using XFA elements, allowing you to use existing XFA forms.
Advanced editing capabilities:
• You will be able to perform various operations with PDF documents: change page contents, select, insert, modify, delete, rotate, copy and paste text, images, graphics and add shadows.
Certification of documents :
• You will be able to determine exactly what changes can be applied to your PDF document.
High compression ratio for scanned documents:
• A high degree of compression of scanned documents will reduce the size of the final file and optimize the process of its processing.
OCR text recognition:
• You will be able to convert scanned documents or regular PDF files into editable text files.
Quick scan:
• Streamline the workflow for converting paper contracts, agreements and other documents into electronic PDF files.
• Scan and convert with one click.
Adding Header and Footer to PDF Files:
• You will be able to add page numbers, headers and footers directly to your PDF file.
Adding watermarks and backgrounds to PDF files:
• You can add watermarks and markings like Confidential, Draft, etc. to PDF files.
• You can add backgrounds to PDF files to make your documents look professional.
Editing and changing PDF content:
• Quickly edit document content and correct errors directly in the PDF file.
• Add text to your PDF file as needed.
Editing documents:
• Adding comments, notes, marks.
• Color highlighting, underlining and other methods of highlighting text.
• Redo and Undo tools.
Comparison of PDF documents:
• Quickly compare two documents to identify the latest changes.
Organizing PDF pages:
• Reorganize PDF pages without directly attaching the document.
• Add, delete, and merge pages from multiple PDF files.
• Change the order of PDF pages by simply dragging and dropping.
Setting up and filling out electronic forms:
• Convert the current form to a PDF electronic form.
• Easy-to-use customization tools let you make your PDF documents more interactive.
• Create and manage a digital signature to quickly add a signature field in the future.
Optimization of PDF documents:
• Reduce file size for easy sharing and processing.
Protect PDF documents with passwords and certificates:
• Control access to PDF documents.
• Protect sensitive PDF documents with passwords.
• Improved security when sending and receiving PDF files.
Adding a digital signature to PDF documents:
• Add digital signature to PDF documents to optimize business processes.
• Increased security through user identification.
• Automatic checking for unauthorized changes to content.
Adding information about a document:
• You will be able to add the necessary information about the document for more convenient archiving and searching.
Additional options for connecting to a Windows ODBC database:
• You can extend customization options by accessing databases via JavaScript.
• Windows 7 (32-bit & 64-bit)
• Windows 8.x Full Version
• Windows 10, 11
• Microsoft Office® 2010 or later version (required for some PDF creation features)
• Verified as Citrix Ready® with Citrix XenApp® 7.13
Recommended Minimum Hardware
• 1.3 GHz or faster processor (x86 compatible) or ARM processor, Microsoft SQ1 or better
• 512 MB RAM (Recommended: 1 GB RAM or greater)
• 2 GB of available hard drive space
• 1024*768 screen resolution
• Supports 4K and other high-resolution displays
 Whats New in Foxit PDF Editor Pro
https://www.foxit.com/pdf-editor/version-history.html
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10/8/8.1/7
Interface language: Multilanguage / Russian / English
Medicine: not required / built-in | pre-activated
File size: 918.62/890.73 MB
Foxit_PDF_Editor_Pro_14.0.0.33046.rar.html
Foxit_PDF_Editor_Pro_14.0.0.33046_Portable.zip.html
