04 de Abril de 2026, 15:03 *
Autor Tema: Autodesk AutoCAD LT 2026.1 Build W.122.0.0 by m0nkrus (RUS/ENG)  (Leído 58 veces)
« : 19 de Agosto de 2025, 00:43 »
Free Download Autodesk AutoCAD LT 2026.1 Build W.122.0.0 by m0nkrus (RUS/ENG)
Autodesk AutoCAD LT 2026 - is designed to develop and detail 2D drawings. The program automates most stages of project execution. A full set of 2D commands allows you to create drawings, modify them and issue working documentation for projects. The program provides built-in support for the DWG format and reliability of operation, and also contains powerful tools to improve drawing productivity. Thanks to this, project files can be easily transferred to other specialists. In addition, you can customize the user interface of the program to your needs.
AutoCAD LT 2026's drafting and detailing capabilities help you effectively implement design ideas, optimize your workflow, and collaborate. AutoCAD LT is a professional solution that supports industry standards and significantly increases designer productivity.
Key features:
• AutoCAD® LT helps you solve the most complex design problems. Freeform modeling tools model a wide variety of solids and surfaces; design review time is significantly reduced; parametric drawings help you keep all the necessary information at hand. Design ideas can be visualized in PDF format, as well as implemented in mock-ups obtained by 3D printing. Never before have ideas become reality so quickly.
• Reduce time costs with parametric drawings. Parametric drawings allow you to significantly reduce the time it takes to review projects. You can set dependencies between objects - for example, parallel lines automatically remain parallel, and concentric circles always have a common center.
• Creative freedom: work with freeform shapes. Now you can implement any project ideas, giving free rein to your creative thoughts. To create complex shapes, simply move faces, edges and vertices.
• Improved PDF support. Sharing and reusing data is surprisingly easy and convenient thanks to improved support for the PDF format. The size of published files has become smaller, TrueType font support has been added. New import and underlay capabilities allow you to add PDF files directly to AutoCAD LT drawings.
• 3D printing of AutoCAD LT 2026 models . You can not only visualize projects, but also implement them into reality. Physical models of projects are created by outputting to a 3D printer (your own or belonging to a specialized company providing 3D printing services).
• Ease of creating and editing dynamic blocks. The introduced improvements helped to simplify the creation and editing of dynamic blocks. Thanks to the improved display and selection of objects, the tools for working with dynamic blocks significantly reduce the time spent on issuing documentation.
Possibilities:
• Impressive graphical presentation. Show your drawings more clearly.
• Enhanced PDF: PDF files are smaller, easier to work with, and easier to search.
• Intelligent dimensioning tools: Create dimensions based on the drawing context.
• Monitoring system variables. Preventing unwanted changes to system settings.
• Project channel. Work in the corporate network, the Internet and when connected to the cloud.
• TrustedDWG Technology. Storing drawings using TrustedDWG™ technology.
• Improved interface: Updated interface that speeds up the design process.
• Advanced Support: Priority technical support via phone or chat and more.
• Import PDF files. The program now has the ability to import files in PDF format.
• Share views: Publish 2D drawings to the cloud.
• Autodesk Desktop App: Manage all your updates with one app.
• Intelligent centerlines and center marks. Quickly create and edit centerlines and center marks.
• Improved transfer tools: Easily transfer user settings and files.
• Resizable dialog boxes: Dialog boxes display more information, reducing the need for scrolling.
• AutoCAD 360 Pro: Create, edit, and view CAD drawings on your mobile device.
New features in AutoCAD LT 2026 :
-  Connected auxiliary files
Now the support files are connected, which means all drawings and project participants in Autodesk Docs can share a single set of support files.
-  Smart Blocks: Search and Transform
In addition to identical blocks, this feature now finds text variations, making repetitive tasks in AutoCAD even easier.
-  Action analytics
For ease of use, we have simplified the search and filter panels. Now you can filter actions by time, users, and specific actions with a single button.
-  CENTERLAYER
The value of the CENTERLAYER system variable can be changed at the command line using the new Layer parameter in the CENTERLINE and CENTERMARK commands.
-  GDI printing improvements
Improved compatibility with Windows system printers, allowing for more efficient handling of custom configuration settings. This enhancement is enabled by default. Print using your preferred Windows system printer as normal. Custom printer settings will be used during printing and saved in the PC3 file.
-  GPU Text
The GPU text selection effect has been improved to improve display quality. A new setting in the Graphics Performance dialog provides better control over how TrueType fonts are displayed when using GPU acceleration. GPU text processing has been optimized for Chinese, Japanese, and Korean languages, as well as right-to-left languages such as Arabic and Hebrew.
-  Increased productivity
Raster images are now loaded asynchronously in the background when opening a drawing file.
List of changes made
What was changed by the author of the assembly :
- The original Russian and English distributions have been merged into one.
- For the modern installer, a solution was developed and implemented for selecting the interface language of the program being installed.
- The interface language of the installer itself is set based on the OS interface language.
- Since AutoCAD LT 2026 lacked the so-called "classic interface" by default, I thought it possible to restore it for those who need it.
- The installation package now includes the ability to install local help for both the English and Russian versions of the program.
- The option to refuse installation of the AutoCAD Activity Insights module has been added to the installation package.
- The installation package now includes the option to refuse installation of the AutoCAD Open in Desktop module.
- The installation package now includes the option to opt out of installing the Autodesk Save to Web and Mobile module.
- The option to refuse installation of the Autodesk CER Service module has been added to the installation package.
- The Autodesk Access module has been excluded from the installation process. The option to install it manually has been left.
- The Autodesk Access Service Host service will be disabled in the program installed from the assembly.
- The Autodesk Identity Manager module has been removed from the installation package.
- The Autodesk Genuine Service module has been removed from the installation package.
- The automatic update mechanism for the Autodesk Licensing module has been disabled.
- AutoCAD LT 2026.1 Update has been integrated into the installation package.
- Autodesk On-Demand Install Service module has been updated to version 2.15.0.546.
- The installer has been updated to version 2.15.0.3.
- Everything you need to cure the program is inside the image in the Crack folder.
Treatment procedure
• Install Autodesk AutoCAD LT 2026 (Setup.exe file).
• Run the AdskNLM.exe file from the Crack folder and wait for the message "Cracking complete. Enjoy!" to appear.
• Run the installed application. In the window for selecting the license type, click "Use a network license".
• Enjoy the registered version of the product!
System requirements :
• 64-bit version of Microsoft Windows 10 (version 1809 or later), Windows 11
• Processor with a clock speed of 2.5-2.9 GHz (3 GHz or higher recommended)
• 8GB RAM (16GB recommended)
• Video adapter with 1 GB of video memory, 29 GB/s bandwidth and DirectX 11 support (4 GB and 106 GB/s and DirectX 12 support recommended)
• 1920x1080 screen resolution with True Color. Windows 10 supports resolutions up to 3840x2160
• 10 GB of free disk space (SSD recommended)
• .NET Framework 4.8 or higher
What's New in Autodesk AutoCAD LT
https://www.autodesk.com/products/autocad-lt/features
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10 (64-bit only)
Interface language: Russian / English
Medicine: crack-AdskNLM
File size: 2.91 GB
Autodesk.AutoCAD.LT.2026.1.ru-en.part1.rar.html
Autodesk.AutoCAD.LT.2026.1.ru-en.part2.rar.html
Autodesk.AutoCAD.LT.2026.1.ru-en.part3.rar.html
Autodesk.AutoCAD.LT.2026.1.ru-en.part4.rar.html
