05 de Abril de 2026, 14:11 *
Autor Tema: Autodesk AutoCAD 2026.1 Build W.122.0.0 by m0nkrus (RUS/ENG)  (Leído 39 veces)
« : 19 de Agosto de 2025, 00:47 »
Free Download Autodesk AutoCAD 2026.1 Build W.122.0.0 by m0nkrus (RUS/ENG)
Autodesk AutoCAD 2026 is more than just design. Shape the world around you with powerful, web-based tools from Autodesk. The product enables you to create stunning 3D designs, produce documentation quickly, and collaborate in the cloud. Designs can be accessed not only from computers, but also from users' mobile devices.
AutoCAD allows you to solve the most complex design problems. Freeform tools model a wide variety of bodies and surfaces; design review time is significantly reduced; parametric drawings help keep all the necessary information at hand. Design ideas can be visualized in PDF format, as well as implemented in 3D printed models. Never before have ideas become reality so quickly.
AutoCAD 2026 delivers powerful collaboration capabilities for designers. New collaboration tools help you engage stakeholders more deeply. Dozens of enhancements speed up everyday processes. Mapping services and new reality capture tools help you incorporate real-world scans into your designs.
Main features :
• AutoCAD 2026® helps you solve your most complex design problems. Freeform modeling lets you model a wide variety of solids and surfaces; design review time is greatly reduced; parametric drawings help you keep all the information you need at your fingertips. Design ideas can be visualized in PDF format and implemented in 3D printed models. Never before have ideas become reality so quickly.
• Reduce time costs with parametric drawings. Parametric drawings allow you to significantly reduce the time it takes to review projects. You can set dependencies between objects - for example, parallel lines automatically remain parallel, and concentric circles always have a common center.
• Creative freedom: work with freeform shapes. Now you can implement any project ideas, giving free rein to your creative thoughts. To create complex shapes, simply move faces, edges and vertices.
• Improved PDF support. Sharing and reusing data has become surprisingly convenient and easy thanks to improved support for the PDF format. The size of published files has become smaller, support for TrueType fonts has been added. New import and underlay capabilities allow you to add PDF files directly to AutoCAD drawings.
• 3D printing of AutoCAD models. You can not only visualize projects, but also implement them into reality. Physical models of projects are created by outputting to a 3D printer (your own or belonging to a specialized company providing 3D printing services).
• Ease of creating and editing dynamic blocks. The introduced improvements helped to simplify the creation and editing of dynamic blocks. Thanks to the improved display and selection of objects, the tools for working with dynamic blocks significantly reduce the time spent on issuing documentation.
Functionality :
• Document production. Efficient documentation in AutoCAD 2026 covers all stages of a project, from initial sketches to the final stage. Automation, data management, and editing tools minimize repetitive tasks and save time.
• Sheet sets. Structuring data is not a luxury, but a necessity. AutoCAD Sheet Set Manager organizes drawing sheets, simplifies publishing, automatically creates views on sheets, and transfers data from sheet sets to title blocks and stamps. All the necessary information is brought together, which greatly simplifies access to it.
• Annotation scaling: You can speed up the management of objects placed on different layers. Annotation scaling creates a single annotative object that automatically scales to the size of the viewport or model space.
• Text operations. Manipulating text while entering consists of its visual placement and scaling. The position of the text can be adjusted using tools familiar from text editors (paragraphs, columns, etc.).
• Create and edit multileaders. You can easily create and edit leaders. Setting up multileader styles ensures their uniformity, allows you to combine several leader lines into one multileader, and include frames and blocks in leaders.
• Working with tables. Using AutoCAD functions, you can automate the painstaking processes of creating and editing tables. By setting the appropriate table style, the font, color, borders and other properties are set at the same time.
• Data Extraction: The Data Extraction Wizard lets you quickly extract data from drawing objects (including blocks and attributes). This data can then be automatically output to tables or external files.
• Link Excel data to AutoCAD drawings. When you link an Excel table to an AutoCAD drawing, you can update the data in both directions. This eliminates the need to edit the tables separately. All information is automatically synchronized.
• Dynamic blocks. Using ready-made elements saves a lot of time. Dynamic blocks free users from having to redraw repeating standard components and maintain cumbersome block libraries. They have the ability to edit individual objects, eliminating the need to create a new block if the shape or size has changed slightly.
• Layer Management: Creating and editing layer properties is now faster and less error-prone. Changes made in the layers dialog box are immediately visible in the drawing.
• Dynamic tooltips and menus: Focus on your work, not your tools. Dynamic input displays command prompts near your cursor, so you can run commands, view dimensions, and enter values without looking at the command line. The Quick Properties menu lets you view and change the properties of objects you want by simply hovering over them.
• User-friendly interface. It is now much more convenient to work with several files simultaneously. The quick view function operates not only with file names, but also with their samples. It simplifies searching and opening the desired file in the desired tab. In the new menu browser, you can navigate through files, view their samples, get information about file sizes and their authors.
Comparison using DWG
Compare and document differences between 2 versions of the same drawing (including drawings inserted via external reference).
Save for use on the web and mobile apps
Save drawings created on your desktop to view and edit in AutoCAD web and mobile apps.
2D graphics
Work with scale, create panoramas, change the drawing order and layer properties - and all this in 2x faster.
General views
Publish drawing views in a web browser so others can examine them and add comments.
AutoCAD web app
Create, edit, view, and share CAD drawings from any device via a browser.
User interface
Significantly improved interface design with new flat icons and 4K resolution support.
Import PDF
Import geometry (including SHX font files), fills, raster images, and TrueType text into drawings from PDF files.
New features in AutoCAD 2026 :
-  Connected auxiliary files
Now the support files are connected, which means all drawings and project participants in Autodesk Docs can share a single set of support files.
-  Action analytics
The new What's Changed insight provides an overview of changes made between Saved actions, so you can continue working efficiently.
-  Import notes and help with notes
The Import Markups and Markup Assist functions have been improved, namely the operation of importing markups from Autodesk Docs into AutoCAD, making it easier to make changes to drawings.
-  Smart Blocks: Search and Transform
In addition to identical blocks, this feature now finds text variations, making repetitive tasks in AutoCAD even easier.
-  Smart Blocks: Detection and Transformation
This release improves the discovery feature and adds the ability to change or edit the primary instance.
-  Adding the "Layer" parameter to the CENTERLINE and CENTERMARKER commands
In this release, the CENTERLAYER system variable has been integrated into the workflows for creating centerlines and center marks.
List of changes made
What was changed by the author of the assembly :
- The original Russian and English distributions have been merged into one.
- For the modern installer, a solution was developed and implemented for selecting the interface language of the program being installed.
- The interface language of the installer itself is set based on the OS interface language.
- Since AutoCAD 2026 lacked the so-called "classic interface" by default, I thought it possible to restore it for those who need it.
- The installation package now includes the ability to install local help for both the English and Russian versions of the program.
- The installation package now includes the ability to install the AutoCAD 2026 VBA Enabler module.
- The installation package now includes the option to opt out of installing the AutoCAD Activity Insights and ADP Insight Client modules.
- The option to refuse installation of the AutoCAD BlockIndexer 2026 module has been added to the installation package.
- The installation package now includes the option to refuse installation of the AutoCAD Open in Desktop module.
- The installation package now includes the option to opt out of installing the Autodesk Featured Apps module.
- The installation package now includes the option to opt out of installing the Autodesk Save to Web and Mobile module.
- The option to refuse installation of the Autodesk CER Service module has been added to the installation package.
- The installation package now includes the option to opt out of installing the Autodesk App Manager module.
- The Autodesk Access module has been excluded from the installation process. The option to install it manually has been left.
- The Autodesk Access Service Host service will be disabled in the program installed from the assembly.
- The Autodesk Identity Manager module has been removed from the installation package.
- The Autodesk Genuine Service module has been removed from the installation package.
- The automatic update mechanism for the Autodesk Licensing module has been disabled.
- AutoCAD 2026.1 Update has been integrated into the installation package.
- Autodesk On-Demand Install Service module has been updated to version 2.15.0.546.
- The installer has been updated to version 2.15.0.3.
- Everything you need to cure the program is inside the image in the Crack folder.
Treatment procedure
• Install Autodesk AutoCAD 2026 (Setup.exe file).
• Run the AdskNLM.exe file from the Crack folder and wait for the message "Cracking complete. Enjoy!" to appear.
• Run the installed application. In the window for selecting the license type, click "Use a network license".
• Enjoy the registered version of the product!
System requirements :
• 64-bit version of Microsoft Windows 10 (version 1809 or later), Windows 11
• Processor with a clock speed of 2.5-2.9 GHz (3 GHz or higher recommended)
• 8GB RAM (32GB recommended)
• Video adapter with 2 GB of video memory, 29 GB/s bandwidth and DirectX 11 support (8 GB and 106 GB/s and DirectX 12 support recommended)
• 1920x1080 display resolution with True Color (up to 3840x2160 recommended for high-resolution and 4K displays)
• 10 GB of free disk space (SSD recommended)
• .NET Framework 4.8 or higher
Additionally for 3D modeling and large data volumes
• At least 32 GB of RAM
• 6 GB of free disk space (excluding space required for installation)
• Workstation-class graphics card with 12 GB of video memory or higher, a display resolution of 3840 x 2160 (4K) or higher, True Color support, Pixel Shader 3.0 or higher, and DirectX support
Whats New in Autodesk AutoCAD
https://help.autodesk.com/view/ACD/2026/ENU/?guid=GUID-FAB1960D-49C1-4A12-B128-5511F7889AB9
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10 (64-bit only)
Interface language: Russian / English
Drug: crack-AdskNLM
File size: 3.49 GB
Autodesk.AutoCAD.2026.1.ru-en.part1.rar.html
Autodesk.AutoCAD.2026.1.ru-en.part2.rar.html
Autodesk.AutoCAD.2026.1.ru-en.part3.rar.html
Autodesk.AutoCAD.2026.1.ru-en.part4.rar.html
