05 de Abril de 2026, 00:27 *
Autor Tema: Bullzip PDF Printer Expert 2025.1.0.2985 Multilingual  (Leído 30 veces)
Conectado Conectado
« : 20 de Agosto de 2025, 00:27 »
Free Download Bullzip PDF Printer Expert 2025.1.0.2985 Multilingual Fast Links | 27.6 Mb
BullZip PDF Printer - a virtual printer allows you to print a PDF document from any application Microsoft Windows, which supports printing. It is enough to specify the PDF Printer instead of the standard and any document, or the image will be converted and saved as PDF file.
Features:
Print to PDF from almost any Windows program.
Supports 64-bit operating systems.
Direct output to the same file each time or prompt for destination.
Control if the printer should ask if you want to see the resulting PDF document.
Control output and prompts programmatically.
Setup can run unattended.
Graphical user interface.
Password protect PDF documents.
AES 256/128 bit encryption and standard 128/40 bit encryption.
Quality settings (screen, printer, ebook, prepress).
Set document properties.
Watermark text, size, rotation, and transparency.
Superimpose/background documents.
Appending/prepending documents.
User interface control.
Linearized PDF documents for fast web view.
PDF/A-1b support for long time storage of PDF documents.
Signing of PDF documents using digital certificates.
Command line interface to all settings.
COM/ActiveX interface for programmatic control.
Microsoft.NET API for C#, VB.NET, and other .NET development.
Support for Citrix MetaFrame
Support for Windows Terminal Server and RDP
Multiple output types supported: BMP, JPEG, PCX, PDF, PNG, and TIFF.
Upload document using FTP or SFTP protocol.
Windows 11, 10, 8.1, 8, 7, Vista, XP and Windows Server 2022, 2019, 2016, 2012, 2008, 2003
https://www.bullzip.com/
xoxpx.Bullzip.PDF.Printer.Expert.2025.1.0.2985.Multilingual.rar.html
