06 de Abril de 2026, 03:46 *
Autor Tema: GraphPad Prism 10.6.0.890 (x64)  (Leído 33 veces)
« : 20 de Agosto de 2025, 21:40 »
Free Download GraphPad Prism 10.6.0.890 (x64) | 192.6 Mb
GraphPad Prism combines scientific graphing, comprehensive curve fitting (nonlinear regression), understandable statistics, and data organization. GraphPad Prism was originally designed for experimental biologists in medical schools and drug companies, especially those in pharmacology and physiology. Prism is now used much more broadly by all kinds of biologists, as well as social and physical scientists. More than 200,000 scientists in over 110 countries rely on Prism to analyze, graph and present their scientific data. It is also widely used by undergraduate and graduate students.
Organize Your Data Effectively
Unlike spreadsheets or other scientific graphing programs, Prism has eight different types of data tables specifically formatted for the analyses you want to run. This makes it easier to enter data correctly, choose suitable analyses, and create stunning graphs.
Perform The Right Analysis
Avoid statistical jargon. In clear language, Prism presents an extensive library of analyses from common to highly specific-nonlinear regression, t tests, nonparametric comparisons, one-, two- and three-way ANOVA, analysis of contingency tables, survival analysis, and much more. Each analysis has a checklist to help you understand the required statistical assumptions and confirm you have selected an appropriate test.
Get Actionable Help As You Go
Reduce the complexity of statistics. Prism's online help goes beyond your expectations. At almost every step, access thousands of pages from the online Prism Guides. Browse the Graph Portfolio and learn how to make a wide range of graph types. Tutorial data sets also help you understand why you should perform certain analyses and how to interpret your results.
One-Click Regression Analysis
No other program simplifies curve fitting like Prism. Select an equation and Prism does the rest-fits the curve, displays a table of results and function parameters, draws the curve on the graph, and interpolates unknown values.
Focus on Your Research, Not Your Software
No coding required. Graphs and results are automatically updated in real time. Any changes to the data and analyses-adding missed data, omitting erroneous data, correcting typos, or changing analysis choices-are reflected in results, graphs, and layouts instantaneously.
Automate Your Work Without Programming
Reduce tedious steps to analyze and graph a set of experiments. It is easy to replicate your work by creating a template, duplicating a family, or cloning a graph-saving you hours of set up time. Apply a consistent look to a set of graphs with one click using Prism Magic.
Countless Ways to Customize Your Graphs
Focus on the story in your data, not manipulating your software. Prism makes it easy to create the graphs you want. Choose the type of graph, and customize any part-how the data is arranged, the style of your data points, labels, fonts, colors, and much more. The customization options are endless.
Operating System:Windows 7, 8/8.1, 10 (64-bit only)
Home Page-http://www.graphpad.com/
59ltj.GraphPad.Prism.10.6.0.890.x64.rar.html
