06 de Abril de 2026, 08:36 *
Autor Tema: Adobe Acrobat Pro 2025.001.20630 Portable (MULTi/RUS)  (Leído 35 veces)
« : 22 de Agosto de 2025, 01:23 »
Free Download Adobe Acrobat Pro 2025.001.20630 Portable (MULTi/RUS)
Adobe Acrobat Pro 2025 is a completely redesigned desktop version of the world's best PDF solution. It includes a mobile app that lets you sign, send, and fill out PDFs from any device. And with Document Cloud, you can create, export, edit, and track PDFs from any web browser. You'll always have the latest versions of your files, no matter what device you're working on.
Your office will be as mobile as you are. Acrobat Pro, powered by Document Cloud services, includes a wealth of tools for converting, editing, and signing PDF documents. You can use it anywhere. Start creating a document in the office, edit it on the way home, and submit the final version for approval from home - it's simple, fast, and convenient.
Acrobat Pro works wonders. Now you can edit any document, even if you only have a paper version at hand. Just take a photo of it with your smartphone and open it in the desktop application. Acrobat will turn the photo into a PDF file before your eyes, which you can edit on your tablet. You can use additional fonts of the same type as in the original document.
Electronic signatures. Everywhere. Acrobat Pro electronic signature services are used on more than a billion devices worldwide. Anyone can add a legally binding signature to a document with a swipe of their finger on a touchscreen device or a few clicks in a browser. Acrobat Pro is more than just a handy app for adding signatures. It makes it easy to send, track, and store signed documents.
Beautiful touch user interface. The new touch user interface in Acrobat Pro makes it easy to access the tools you need and is designed for mobile devices. Try it and you won't change it.
Program features:
Merging files.
- Keep it all in one document. Combine and organize documents, spreadsheets, emails, and other files within a single PDF document.
Scan to PDF.
- Convert paper documents into editable, searchable PDF files. Copy and paste text to reuse across multiple documents.
Standardize everyday operations with PDF format.
- The steps to create PDF files are always the same. Just follow the step-by-step instructions on the screen.
Protect PDF files.
- When sharing files, be sure that they are safe. Block copying and editing functions of your PDF documents.
Create fillable forms.
- Convert existing paper documents, Word files, and PDF forms into electronic forms that are easy to fill out and sign.
Access to tools from any device.
- Access PDF tools and recently opened files from your office, home computer, or mobile device.
Take advantage of a comprehensive PDF solution wherever you are.
- Work on Mac, Windows, and mobile devices.
- Create high-quality PDF files.
- Edit and export PDF files to Office documents.
- Signing and sending PDF files for signing.
- Instantly edit scanned PDF documents.
- Edit and organize PDF files on your iPad.
- Add audio and video recordings to PDF files.
- Consistently prepare PDF files using guided actions.
- Deleting confidential information without the possibility of recovery
Benefits of Adobe Acrobat Pro 2025
- Adding queries when AI processes a document
Now when you process a PDF file with AI, a text box appears that allows you to start writing questions right away. This helps you organize your thoughts and reduces downtime. Once processing is complete, you can ask your questions right away.
- Switch to another file to work with generative AI
AI Assistant and Generative Summary now include a Try Another File button that makes it easier to switch between files if the current file is not supported. You can select another file directly when an error occurs, so you can continue working immediately without wasting time. The error message appears if the file is empty or does not contain enough text. Click Try Another File, then select a new file. Once loaded, you can continue working with AI features.
- Improved AI suggested questions based on document types
Now, depending on the document type, you can see more relevant suggested questions in the Ask AI Assistant field. Custom questions allow you to create results that are relevant to the document type. For documents that are not confidential, a field appears for entering questions manually.
- "Ask AI Assistant" option added to context menu for scanned PDF documents
You can now select text or an image in a scanned document and use the Ask AI Assistant option directly in the context menu. This context menu option makes it easy to interact with the AI ​​Assistant, even when it comes to images and text in scanned documents.
Assembly information
To unpack the program, run "Acrobat Pro.exe".
The program startup file "AcrobatProPortable.exe".
Selecting a language when you first start the program.
Change language: Edit, Settings, Language, Application language:
"for example - Russian"
or
"Select when starting the program"
or
"Like in OS"
Available languages: cs_CZ,da_DK,de_DE,en_AE,en_IL,en_US,es_ES,
fi_FI,fr_FR,fr_MA,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,
pt_BR,ru_RU,sk_SK,sl_SI,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW.
Not installed: cloud, telemetry.
Since the program is running as administrator,
drag and drop doesn't work, use: File-Open... or
Open with...
Does not require installation of libraries in the system.
Added hosts, hosts are removed on shutdown.
To set associations, use "Open with".
To completely reset all settings and preferences, delete the folder
Data by path: Acrobat Pro\Data.
System requirements:
• Intel or AMD processor with a clock speed of 1.5 GHz or higher
• 64-bit versions of Microsoft Windows 11, Windows 10 (version 1809 or later), Windows Server 2016-2019; 64-bit versions of Microsoft Windows 11, Windows 10, Windows 8.x, Windows 7 SP1, Windows Server 2008R2-2019
• 2GB RAM
• 4.5 GB of free hard disk space
• Display with a resolution of 1024?768
• Hardware video acceleration (optional)
Whats New in Adobe Acrobat Pro
https://helpx.adobe.com/acrobat/using/whats-new.html
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10 (32-bit/64-bit)
Interface language: Multilanguage / Russian / English
Medicine: not required / built-in | pre-activated
File size: 1.14/1.19 GB
Adobe_Acrobat_Pro_2025.001.20630_x64_Portable.7z.html
Adobe_Acrobat_Pro_2025.001.20630_x86_Portable.7z.html
No Password  - Links are Interchangeable
