Free Download Adobe Media Encoder 2025 25.4.0.90 Portable (MULTi/RUS)Adobe Media Encoder 2025 is a universal application for processing any media content. Insert, transcode, create proxy versions and output in any desired format. The program provides unified functionality for working with multimedia files in various applications. Thanks to tight integration with Adobe products and other applications, the process of processing media content is simplified and accelerated.
Advantages of Media Encoder:• Allows you to process multiple video and audio clips in batch mode, speeding up your workflow.
• Media Encoder is an encoding engine for Adobe Premiere Pro, After Effects and Prelude, and can also be used as a standalone encoding tool.
• AS-11 Packet Creation with DPP: Media Encoder now offers the ability to create files based on the widely used AS-11 UK DPP version 1.1 standard for UK broadcast, alongside other encoding options.
• Two new Dolby codecs have been added: Dolby Digital Plus and Bluray compatible. You can also set additional Dolby Digital settings.
• Updates to import and export settings: Expanded support for XAVC. You can now export to XAVC HD Class 200, XAVC 2K/4K 24p, and XAVC 4K Class 480.
• Additional XDCAM options are available. New settings can be used to work with open and closed groups of pseudo frames, as well as groups of pseudo frames with fixed or variable duration.
• Support for importing SStP files is now available. Red frames are no longer added to MXF OP1a media when Media Encoder fails to encode a frame. Instead, an adjacent frame is inserted and a warning is recorded if an encoding error occurs.
• Set frame rate for media without their own timeline: There is a new Undefined Media Timeline preference in Edit > Preferences > Media that lets you set the frame rate for source media without their own timeline, such as image sequences.
• Sync Settings: The first time you use File > Sync Settings in Media Encoder, your settings and templates will be imported.
• QuVIS's Wraptor DCP (Digital Cinema Package) exporter is a quick and easy way to export your project to a cinema-ready format with 2K resolution, 24 fps and up to 5.1 audio configuration.
Importantly,
Adobe Media Encoder 2025 lets you process multiple video and audio clips in batch mode; in environments where video is a significant part of the content, batch processing speeds up the workflow. As the program encodes video files, you can add, reorder, and change the encoding settings of files in the batch queue.
Adobe Media Encoder 2025 supports various video export formats depending on the Adobe applications installed with the program. Specifically, it is the encoding engine for Adobe Premiere Pro, Adobe After Effects, and Adobe Prelude. However, the program can also be used as a standalone encoding tool.
Features in Adobe Media Encoder:• Selecting a channel when publishing on YouTube and Vimeo
• Select a playlist when publishing to YouTube
• Selecting a page when posting to Facebook
• Add your own title when publishing to YouTube, Facebook and Vimeo
• Add your own video thumbnail when publishing to YouTube
• Notification of missing queue positions before coding starts
• Adaptive H.264 bit rate settings that automatically select the optimal bit rate for output based on the size and frame rate of the source video
• Support for exporting GIF animations to Mac and Windows
• Improved Time Tuner effect
• New optimized H.264 settings list
• Supports RF64 WAV encoding/decoding, Sony X-OCN decoding and QuickTime DNx intelligent rendering
• Warning when importing QuickTime sources of other formats
• Changing timecode for media content with 720p resolution 59.94
Benefits of Adobe Media Encoder 2025- Comparing source and output data in the AME Export Settings dialog box
The Export Settings dialog now lets you compare previews of source and output data.
- Support hardware decoding
Media Encoder now supports hardware decoding of AVC Long GOP, HEVC-Intra, and HEVC-Long GOP files in an MXF container.
- Automatic detection and interpretation of logarithmic iPhone ProRes video
You can now enable the Auto-Detect Logarithmic Video Color Space option and drag a logarithmic iPhone ProRes camera source media clip onto a Rec 709 timeline.
System requirements :• 64-bit version of Microsoft Windows 10 / 11 (version 22H2 or later); 64-bit version of Microsoft Windows 10 / 11
• 6th Gen Intel or AMD Ryzen 1000 processor with AVX2 support (11th Gen Intel processor with Quick Sync support or AMD Ryzen 3000 / Threadripper 3000 or newer recommended)
• 8GB RAM (16GB recommended for HD media; 32GB recommended for 4K media)
• 8 GB of available hard disk space; additional free space required during installation
• Video card with 2 GB of video memory (8 GB recommended)
• 1024x768 (VGA) screen resolution (1920x1080 or higher recommended; DisplayHDR 1000 for HDR workflows)
• Sound card with ASIO or Microsoft Windows Driver Model support
• 1Gbps network card for HD media sharing (10Gbps recommended for 4K media sharing)
• Internet connection and registration required to access online services
Assembly informationTo unpack the program, run "Media Encoder.exe".
The program startup file "EncoderPortable.exe".
Does not require installation of libraries in the system. Does not leave traces in the system.
and the registry.
Switch language:Edit\Settings\Appearance\Language:
Edit\Preferences\Appearance\Language:
OK
Available languages:cs_CZ, de_DE, en_US, es_ES, fr_FR, it_IT,
ja_JP, ko_KR, nl_NL, pl_PL, pt_BR, ru_RU,
sv_SE, tr_TR, zh_CN, zh_TW.
Folders:
Documents\Adobe\Adobe Media Encoder
Documents\Adobe\Common
Documents\Adobe\Premiere Pro
located in
Media Encoder\App\Documents\Adobe
will be generated when the program is launched.
To reset language settings, delete
Media Encoder\App\Documents\Adobe\Adobe Media Encoder\24.0\AMEPrefs.xml
Whats New in Adobe Media Encoderhttps://helpx.adobe.com/tr/media-encoder/using/whats-new.html
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10 (64-bit only)
Interface language: Multilanguage / Russian / English
Medicine: not required / built-in | pre-activated
File size: 719.17 MBBuy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorAdobe_Media_Encoder_2025_25.4.0.90_Portable.7z.htmlUploadCloudAdobe_Media_Encoder_2025_25.4.0.90_Portable.7z.htmlFikperAdobe_Media_Encoder_2025_25.4.0.90_Portable.7z.htmlNo Password - Links are Interchangeable
