06 de Abril de 2026, 19:17 *
Autor Tema: Handy GPS v44.4  (Leído 28 veces)
« : 24 de Agosto de 2025, 06:12 »
Free Download Handy GPS v44.4 | Android | 31.2 MB
Paid version
The perfect companion for your next outdoor adventure.
Seek, find, record and return home with Handy GPS. This app is a powerful navigation tool designed for outdoors sports like hiking, bushwalking, mountain biking, kayaking, boating, and horse trail riding. Its also useful for surveying, mining, archaeology, and forestry applications. Its simple to use and works even in the remotest back country since it doesn't require network connectivity. It allows you to work in UTM or lat/lon coordinates so you can even use it with your paper maps. Waypoints and track logs recorded in the field can be be viewed later in Google Earth.
Base features
- Shows your current coordinates, altitude, speed, direction of travel, and distance travelled in metric, imperial/US, or nautical units.
- Can store your current location as a waypoint, and record a track log to show where you've been on a map.
- Data can be imported from and exported to Google Earth KML and GPX files.
- Allows manual entry of waypoints in UTM, MGRS and lat/lon coords.
- Can guide you to a waypoint using the "Goto" screen, and optionally sound an alert when when you're getting close.
- Has a compass page which works on devices with magnetic field sensors.
- Automatically computes the local geoid offset to improve altitude accuracy
- Supports the world-wide WGS84 datum along with the common Australian datums and map grids (AGD66, AGD84, AMG, GDA94, and MGA). You can also use WGS84 for NAD83 maps in the US.
- Shows GPS satellite locations and signal strengths graphically.
- Can display simple or MGRS grid references.
- Can compute waypoint-to-waypoint distance and direction.
- Includes an optional timer line to record walk duration and compute your average speed.
- If you have an Android Wear smartwatch, a stand-alone watch version of the app will also be installed.
- Can be used as a replacement for the old "MyTracks" app.
- Thoroughly tested by the developer on many off-track walks
Requirements: Android 5.0+
https://play.google.com/store/apps/details?id=binaryearth.handygps&hl=en
gmgnm.Handy.GPS.v44.4.apk.html
