05 de Abril de 2026, 19:41 *
Autor Tema: VAG DPF v4.43.15  (Leído 27 veces)
« : 24 de Agosto de 2025, 13:12 »
Free Download VAG DPF v4.43.15 | Android | 5.4 MB
VAG DPF shows you the most important data related to the DPF particulate filter and its regeneration phases using an ELM327 Bluetooth/WIFI adapter.
With this app you can know if the filter is actually in regeneration process, if a regeneration is waiting to complete, how many km have you traveled since last regeneration, etc. This app doesn't use standard OBD2 commands as almost all other apps, it uses directly CAN commands specific of car model and this is the reason why it doesn't work with every car; due to the use of CAN commands, the app needs al least a decent ELM327 adapter (see note below); some users reports correct app working with a 10-15 euro adapter.
ATTENTION! This app works only with VAG (Audi Volkswagen Seat Skoda) that are equipped with engines listed below; for diesel engines not listed is not guaranteed the full compatibility, so if you anyway buy the app, consider that some or all functions couldn't work correctly.
IMPORTANT! Before buying this app I suggest to try the app "VAG DPF Free" to check the correct functionality of your adapter and your Android because the free application shares the connection method and the data reading code so it's perfect to test if these important functions are working correctly.
Engines supported
- DETA, CRBC, CFHD,CUNA, CFFB, CFWA(*), CLHA, CXXB, CAYC (partially working on Passat 3C MY10), CAHA (beta, requires verification), CXHA
Engines tested successfully by users
- CFGB(*), CFGC, CJCA, CRMB, CUPA, CUSA, CXFA, CAYB, CAYD, CRLB, CUTA, CFHC, CAGA(*), CSHA, CJCD, DFSB, CLAB, DFLA, DCXA, CFCA, CGLC, CFJB, CFHA, CRUA, DDYA, DFFA, CRKB, DCYA, DFCA, CUUB, CGLB, CUAA, CUSB, CAPA(*), DFGA, DFSF, DFHA, CNHA, DGTE(*), CCWA, DGDA, DLUB, CJCB, DGTD, CDUD, CSUD, DAUA, DJGA, CXXA, DFEA, DBGC, CAYA, CRTD, DGDB, CUUA, DAVA, CKFC, CRCA, DTTC
(*) = partial support or depending on SW version
Requirements: Android 5.0+
https://play.google.com/store/apps/details?id=com.applagapp.vagdpf&hl=en
c2kak.VAG.DPF.v4.43.15.apk.html
