Free Download Hitek JaSFTP 13.16 | 65 MbJaSFTP - Automated Secure File Transfer Protocol (SFTP)
Features:
Simple User Interface helps you transfer files interactively, but the Goal is to get you to create advanced SFTP tasks that can be scheduled to automatically or to run manually.
Automate SFTP to/from an intranet or internet server. Schedule SFTP of files between your PC and the server; and automatically rename the files based on current month, day or time if needed. SFTP supports wildcards (*). Transfer multiple files at once. Supports subdirectory transfers.
Remote SFTP directory monitor can detect directory change and trigger SFTP , zip, copy, delete tasks. It can also detect ✅
File Size, total files, file modification dates and then trigger other tasks, if required.
Email Notification for all tasks based on task exit code.
Local directory monitor works similar to the Remote SFTP directory monitor.
Dynamic variables are supported for most tasks. Most tasks also generate variables which can be used in other tasks.
Create advanced automation solutions using our tasks in conjunction with variables, directory/file monitors and our task chains.
Automate SFTP to/from an intranet or internet server. Schedule SFTP of files between your PC and the server and automatically rename the files based on current month, day or time if needed. SFTP supports wildcards (*). Transfer multiple files at once. Supports SFTP logging and can be used as an SFTP daemon. Secure SFTP module is available as an add-on.
SFTP Command task can run SFTP commands in sequence.
Schedule downloads of your favorite sports, weather, news or entertainment web page from the internet. You can automate downloads to a local filename based on the current month, day, or time for archiving. Web downloads supports Proxy Authorization for folks behind proxy servers.
Monitor websites for any updates. Downloads any web page that has been modified.
Multiple Connections with Unlimited simultaneous task threads
Unlimited SFTP browsers can be opened
Automatically Caches Remote SFTP Directories during automated tasks.
Support for both SSH protocols, SSH1 and SSH2
Password, Public key authentication
HTTP, SOCKS 4 and SOCKS 5 proxy support
You can run all tasks from the commandline using a Task Runner feature.
Task Runner feature allows you to run tasks from other programs.
Commandline module is also available to allow you to control the software via SSH from a remote system.
The engine that runs the tasks in the background can be run as a Windows Service or a Service on MacOSX and Linux.
Supported Platforms:Windows 8.1, 10, 11, 2012R2 server, 2016 server, 2019 server, 2022 server. Includes JRE 17 (java 17).
Requires JRE 17 (java 17)to be installed separately from OpenJDK.
Home Page -http://www.hiteksoftware.com/Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorxevay.Hitek.JaSFTP.13.16.rar.htmlFreeDLxevay.Hitek.JaSFTP.13.16.rar.htmlLinks are Interchangeable - No Password - Single Extraction
