05 de Abril de 2026, 00:53 *
Autor Tema: Hitek Automize Enterprise 13.16  (Leído 37 veces)
« : 24 de Agosto de 2025, 21:54 »
Free Download Hitek Automize Enterprise 13.16 | 68 Mb
Automize - Automation software suite to improve your productivity and save time.
Features
Automation software for Mac. We develop and test on Mac.
Automation software for Windows. We also develop and test on Windows.
Task scheduler allows you to schedule tasks, execute tasks as well as other software programs and applications. No programming or script knowledge is required.
Email Notification for all tasks based on task exit code.
Dynamic variables are supported for most tasks. Most tasks also generate variables which can be used in other tasks.
Create advanced automation solutions using our Automize tasks in conjunction with variables, directory/file monitors and our task chains.
Command and Windows Command tasks can run your batch files, scripts or executable programs. It can also terminate them or obtain their exit codes for use in other Automize tasks.
Chain Task Integrator includes Commands, database SQL, check email, FTP, Web downloads, send email, URL monitors, telnet, ping, copy, print files etc.. Run multiple programs, commands, FTP, email, web downloads etc.. in sequence with options depending on Exit codes.
Scripting: For advances users, you can develop scripts that reduce repeated, laborious computer-related activities. You can also create complex automation scripts which build upon existing Automize tasks. Automation scripting features are available in the Automize Enterprise edition. Scripts can be written in Java, Javascript, Groovy, Ruby, Python, Tcl, AWK and other languages!
Automate FTP to/from an intranet or internet server. Schedule FTP of files between your PC and the server and automatically rename the files based on current month, day or time if needed. FTP supports wildcards (*). Transfer multiple files at once. Supports FTP logging and can be used as an FTP daemon. Secure FTP module is available as an add-on.
FTP Command task can run RFC FTP commands in sequence.
Automate XML tasks. XML loop , XML monitor, XML validate
Automate PGP encryption and decryption tasks
Schedule downloads of your favorite sports, weather, news or entertainment web page from the internet. You can automate downloads to a local filename based on the current month, day, or time for archiving. Web downloads supports Proxy Authorization for folks behind proxy servers.
Monitor websites for any updates. Downloads any web page that has been modified.
Check email and download email with attachments. Only messages meeting user set subject, date or sender conditions are downloaded.
Schedule email messages with attachments to multiple recipients.
Database SQL. Automatically send SQL statements to databases. Monitor a database table for changes
Telnet can be automated. Schedule Telnet commands. The Advanced Telnet Task can wait for your commands to finish (by detecting the telnet prompt); and then send the next telnet command.
Ping a server to check if it is up. Maintains uptime statistics for your server.
Automate programs, tasks or batch files with command line arguments. Launch a schedule program and pass command line arguments and start/working directory information to it.
Zip files and directories using wildcards on schedule. Can append date/time to filename for archive purposes.
Copy files and directories using wildcards on schedule. Can append date/time to filename for archive purposes.
Schedule task or Automate Microsoft Office products: Schedule a MS Access, Excel, MS Word, PowerPoint macro or other command-line startup switch. You can also schedule an Access macro and compact or repair the database.
Print document files or delete files on a schedule
Monitor directory tree for changes
Schedule alarms, message reminders
You can run all tasks from the commandline using a Task Runner feature.
Task Runner feature allows you to run tasks from other programs.
Commandline module is also available to allow you to control the software via SSH from a remote system.
The engine that runs the tasks in the background can be run as a Windows Service or a Service on MacOSX and Linux.
Supported Platforms:
Windows 8.1, 10,11, 2012R2 server, 2016 server, 2019 server, 2022 server. Includes JRE 17 (java 17).
Requires JRE 17 (java 17)to be installed separately from OpenJDK.
Home Page -http://www.hiteksoftware.com/
vnmnk.Hitek.Automize.Enterprise.13.16.rar.html
