Free Download SolidCAM\CAD Suite 2025 SP2 HF1 | 12.9 GbLanguages Supported: 中文, Čeština, Dansk, Nederlands, English, Français, Deutsch, עברית,
Magyar, Italiano, 日本語, 한국어, Polski, Português, Русский, Español, Türkçe.SolidCAM jointly with Dassault Systemshas released
SolidCAM\CAD Suite 2025 SP2 HF1, is the complete, 'best-in-class' Manufacturing Suite for efficient and profitable CNC-Programming standalone.
Owner:SolidCAM
Product Name:SolidCAM/CAD Suite *
Version:2025 SP2 HF1
Supported Architectures:x64
Website Home Page :www.solidcam.comLanguages Supported:multilanguage
System Requirements:Windows **
"SolidWorks 2024 SP5"
"SolidCAM2025"
"SP2 HF1"
Language: Embedded 64 bit
Last Changed Rev: 160265
Warning: Do not install this program on a computer with SolidWorks installed.SolidCAM 2025 New FunctionalitiesGeneralSynchronize Operation to its Updated Template- You can now update your operations that used templates with changes you made in the Template
Quick tool selection in Operation- Option to select a tool from Quick Tool Selection menu
- Option to select tool from the Machine Preview by double-click
SolidCAM Settings - Clearances per Machine Definition- Added settings to define Clearance settings defaults per MachineAdded SolidCAM Settings to trigger whether to use Machine or Global settings
SolidCAM 2025 SP2 HF1 Release Notes - Date: Jul 31 2025SOL-33048 Expanding SolidCAM Capabilities for SolidWorks PO Users Implemented
SOL-34240 Transform||4x doesn't works correct
SOL-34426 Engraving || Crash || Solidcam crashes when adding an engraving job
SOL-34400 Setup || Machine Preview || Workpiece preview on second PM stops working correctly if both target and stock are hidden
SOL-34351 PO || PRT and PRZ || Configurations || Stock and Target are lost after confirm
SOL-34333 Performance || Often crashing when dealing with large CAM projects.
SOL-34332 VMID || Auto-calculate Axes Numbers || It takes into account axes in channel declared as Normal
SOL-34302 PO || PRT and PRZ || Part with Configuration || Unable to pick configurations for the Stock and Target
SOL-34298 WireEDM || Templates || We do not take data into account
SOL-34292 Calculate CAM-parts || MW based operation is not calculated using Calculate CAM-Parts option
SOL-34253 MCO || WCS || Wrong last location after table part move
SOL-34231 WireEDM || Empty Process Point table
SOL-34226 Machine Simulation || Missing Start/End Program and Workpiece and Stock in Simulation
SOL-34220 General || Geometry invalid if it contains a character unusual for English alphabet
SOL-34211 ToolKit || Flip icon does not change for the first click and this leads to the problem
SOL-34197 Setup || Fixture || Selected Fixture Disappears After Using "CleanUp CAM Part" on Converted Part
SOL-34139 CZ translation of CIMCO message
SOL-34134 Regression || Lock Toolpath || Toolpath start point is changed to bottom of the part
SOL-34119 PO || General || Merge branch SC 2025 PO into SC2025 DV/SP2
SOL-34093 ToolKit || TLV || Allow ENTER for confirm
SOL-34089 Templates || Sync. and Calculate Linked Template gauges part
SOL-34065 ToolKit || Issue with Joints CS in TLV
SOL-34064 VMC || Machine Preview || STL are not visible in all configurations
SOL-34063 PO || PRT and RPZ || Setup || Fixture || I cannot shift or rotate fixture in any direction
SOL-34053 G-code || Change bit is incorrect for SM movement in PartCS mode and also rt set is not correct
SOL-34051 PO || PRT and PRZ || CAM Part definition || Assembly (SLDASM) is not supported -Add a message to inform a user
SOL-34050 PO || PRT and RPZ || General || Tool Tip || Add tool tip for "Part mode" checkbox
SOL-34046 Setup - Machine Preview - Part Mounting sign - Doesn't exist in the right location
SOL-34038 MCO || List || Values are missing after part is reopened
SOL-34025 MCO || WCS is incorrectly shown in the Machine preview
SOL-34010 CAM-Tree || Indent according to the tools is not showing correct CAM-Tree when MCO is with the tool
SOL-33992 MCO | not able to place MCO-Job after first Job
SOL-33971 PO || PRT and PRZ || HoleWizard Process || Old Recognition || SW crash on multiple Fixed hole selection
SOL-33960 PO || PRT and PRZ || HoleWizard Process || Old Recognition || Not working for the thru Counter Sink hole
SOL-33955 Operation Sequence Manager || Freeze when syncyng 3 operations
SOL-33952 MCO - Technology ComobBox - Doesn't seem well
SOL-33950 PO || PRT and PRZ || HoleWizard Process || Getting a crash while HWZD Recognition
SOL-33947 MCO Cycle || SolidCAM crashes on change default parameter value
SOL-33921 Millturn || Job sequence manager || Changed sequence is not saved
SOL-33891 SC2025/Setup/Adding fixture on BS make part mounted on BS -> Force unecessary clicks and broke existing ChannelSynch
SOL-33864 Setup Sheet || General || Newparameter
SOL-33852 JWA | SC2025 | Axis limit warning for multiple tools
SOL-33830 PO || PRT and RPZ || Stock definition || Function "Create 3D model" is not working
SOL-33827 PO || PRT and RPZ || Envelope || Cannot calculate operation
SOL-33826 Revese Turret + Second Angle Pair = Wrong Coord. XWPOS YWPOS
SOL-33814 get_axis_current_status | Wrong Value
SOL-33811 PO || implement Hole Wizard functionality
SOL-33784 PO || PRT and RPZ || Direct changes on SLDPRT || Reopen CAM project makes SC crash
SOL-33768 PO || PRT and RPZ || Modify Design model || Using Edit in context - Infinite message about updating
SOL-33747 VMC || Suppress parameters flickers the icon
SOL-33740 2.5D || Point interpolation should not be possible with tolerance 0
SOL-33733 PO || PRT and RPZ || Change reference model || Makes SolidCAM Crash
SOL-33710 VMC || Working Style || Coordinate System || Auto-Create settings parameter small GUI issue
SOL-33701 PO || PRT and RPZ || Geometry selection || Wireframe || Wrong behavior of chain selection by start/end
SOL-33667 CLONE - PO || GUI || New External Cam-Part || Check box for part only mode
SOL-33654 PO || PRT and RPZ || Geometry selection || Wireframe || Highlighting a geometry is not working
SOL-33546 PO || PRT and RPZ || General || Each item from CAD tree is opened on the background
SOL-33541 PO || PRT and RPZ || New CAM-part || After completing the project definition, it moves me under CAM part
SOL-33538 PO || PRT and RPZ || Synchronization || Modify a 3D model || Missing Sync. marks and wrong behavior
SOL-33536 PO || PRT and RPZ || Add box to CAD model || Sketch is not created and wrong behavior
SOL-33523 PO || PRT and RPZ || Cordsys || Strange screen flashing when modify cordsys
SOL-33517 PO || PRT and RPZ || Envelope || Envelope is not correct with any option - Wrong behavior
SOL-33515 MCO || Setting and layout of the MCO changes after GPP replacement and reloading of the Part
SOL-33479 PO || GUI || New External Cam-Part || Check box for part only mode
SOL-33250 ToolKit || Order of the string in search box should not influent the result
SOL-33049 SC PO || Add External mode
SOL-33022 VMID || Implement smallest size of VMID window
SOL-31322 SolidVerify || Incorrect representation of the tool
SOL-29025 Setup Sheet || d.xml || SCOperations || No section for Thread Whirling is generated
SOL-28600 Definition For Face-Mill Tool ||does not calculate with changed cutting position
SOL-26359 SolidCAM-Simulator | Customer Jabil | Holder orientation is wrong while and after transform 4x
SOL-25171 ToolBox Cycle | Broaching | Machine Simulation | Tool ist not displayed correctly
SOL-18557 Setup Sheet || d.xml || General || Newparameter
SOL-34229 2D iMachining || wrong coordinates if nested subroutines used
SOL-34203 Regression || Process Template || Operations unselected when we move the cursor on it
SOL-2047 QA\millturn\calculate of drill turning job a lot of time-looks stuck up
SOL-34386 PO || PRT and PRZ || Part with Configuration || HWZD Recognition || SolidWorks Getting Crash
SOL-34222 CAM Tree || select all operations with this home || selection vanishes
SOL-34160 Process Template || MCO || Inconsistent Submachine Recognition When Importing MCO Operations from Process Template
SOL-4343 machsim / wrong preview stock after cut off and transfer part transfer
SOL-33680 Machine Simulation || Fails with "Cannot create Updated Stock" Error When Setup Is Not Defined
SOLIDWORKS3D CAD solutions provide engineers, designers, and manufacturers with the design, simulation/verification, manufacturing, file management, and collaboration tools they need to develop and manufacture innovative products and equipment - in one package. All SOLIDWORKS software products provide single-window, fully-associative integration with SOLIDWORKS 3D CAD software. As a result, SOLIDWORKS products work together using the same design data. So, each design change is updated automatically across all applications. SOLIDWORKS is easy to use, allowing you to become productive almost immediately. It's powerful and industry-proven, providing the depth of functionality needed to handle the most complex designs and largest assemblies. From the beginning, SOLIDWORKS has been at the forefront of making design accessible to every designer and engineer. Our job is putting you in a position to create, collaborate, and deliver innovative product experiences with powerful, yet easy-to-use product development solutions.
SOLIDWORKS 2024continues this expectation, while opening new possibilities to enhance the way you design, communicate, and manage your 3D designs with SOLIDWORKS. Work Smarter. Work Faster. Work Together with SOLIDWORKS 2024.
What's New in SOLIDWORKS 2024 - SOLIDWORKS LiveJoin a team of SOLIDWORKS experts to walk through the latest and greatest capabilities available to you with SOLIDWORKS 2024. We will dive deep into the newest CAD enhancements to boost your productivity by automating and shortening workflows and working faster with the latest performance and interface improvements. You'll also learn how to take advantage of new file management capabilities with Cloud Services, including secure, powerful sharing and CAD-aware cloud storage.[SolidCAM/CAD provides a powerful, easy-to-use, complete CAD/CAM solution that support the complete range of major manufacturing applications including 2.5D Milling, Multi-sided Indexial 4/5 axes Milling, Simultaneous 5 axes Milling, Turning, Mill-Turn for Multi-Turret and Multi-Spindle CNC machines, with the revolutionary iMachining, provides the complete functionality of CAD and CAM, including iMachining.
SolidcamSolidCAM, a global leader in innovative CAM software for CNC machining and distribution of related digital manufacturing solutions, has more than 20,000 CNC manufacturing customers worldwide
Dassault Systèmes, the 3DEXPERIENCE Company, provides business and people with virtual universes to imagine sustainable innovations. Its world-leading solutions transform the way products are designed, produced, and supported. Dassault Systèmes' collaborative solutions foster social innovation, expanding possibilities for the virtual world to improve the real world. The group brings value to over 250, 000 customers of all sizes, in all industries, in more than 140 countries.
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorSolidCAMCADSuite2025SP2HF1FreeDownload.htmlUploadCloudihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part1.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part2.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part3.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part4.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part5.rar.htmlFikperihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part1.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part2.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part3.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part4.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part5.rar.htmlFreeDLihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part1.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part2.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part3.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part4.rar.htmlihj42.SolidCAM-CAD-Suite-2025-SP2-HF1-Free-Download.part5.rar.htmlLinks are Interchangeable - No Password - Single Extraction
