06 de Abril de 2026, 07:07 *
Autor Tema: Enolsoft PDF Converter OCR 2.0.0 Multilingual Portable (x64)  (Leído 32 veces)
« : 26 de Agosto de 2025, 08:38 »
Free Download Enolsoft PDF Converter OCR 2.0.0 (x64) Multilingual Portable Fast Links | 370.5 Mb
Enolsoft PDF Converter OCR converts native and scanned PDF to Word, Excel, PowerPoint, Pages, Keynote, Numbers, image, etc.
PDF Converter OCR
- Convert PDF to Word, Excel, PPT, Keynote, Pages, HTML, EPUB, Text, Rtfd, images and etc.
- Use OCR function to convert scanned PDF to searchable PDF and other documents.
- Faithfully reproduces complex layouts, even those with tables and graphics.
- Create PDF from Word, Excel, PowerPoint, Text, HTML, CHM, etc.
Easily Convert PDF Files to Other Formats
Convert PDF to editable formats like Word, Excel, Keynote, Pages, images, etc.
Reuse and Edit PDF Content, in the Format of Your Choice.
Presenting information in different file format can get totally different effect, we get used to store and deal with data in Excel, use PPT in meeting, take notes in Text. But how to quickly generate those formats with one PDF file?
Enolsoft PDF Converter OCR can help you easily convert native and scanned PDF to Word, Excel, PPT, Keynote, Pages, HTML, EPUB, Text, Rtfd, images and etc. No matter you want to analyze data, report work to your boss, or have a meeting with your colleague, it can be your great partner.
Save Time and Effort with Batch PDF Processing.
A perfect report or prospectus may need to synthesize different kinds of data that comes from different files. But if you want to merge or extract them, retype the word or re-make the Excel manually will waste much time.
With PDF Converter OCR, you can batch add and convert PDFs to the format you want without quality loss, then you can copy the information freely. Put simply, PDF Converter OCR helps you work better, smarter, and faster.
Stop Retyping! Editing Is Easy.
No permission to edit encrypted PDFs, scanned PDFs, or images? Retype the content is not the only way to extract the information!
Enolsoft PDF Converter OCR makes your edit be much easier. It can help to remove the PDFs' restriction password automatically before converting, and convert scanned PDFs or images to the editable formats with OCR technology.
Be More Productive with OCR
Enolsoft PDF Converter OCR can accurately recognize the text, images, and table in the PDFs to assure to keep the original layout. Quickly deal with all files from your boss, partners or colleagues.
Professionally Create PDF from Various Files
Create PDF from 10+ file types: Word, Excel, PowerPoint, Pages, Keynote, Numbers, image, etc.
Make a PDF from Existing Documents, No Need to Create from Scratch.
Manually typing into a blank PDF page is time consuming and tedious, most of the PDF files are actually created from an existing document, with intact information and good formatting. Therefore, creating PDFs can be much easier than you expect.
Enolsoft PDF Converter OCR allows users to create PDF from 10+ file types: Word, Excel, PowerPoint, Pages, Keynote, Numbers, CHM, ePub, HTML, Text, RTF, JPEG, PNG, GIF, BMP, TIFF, TIF, JPG. Also, you can merge multiple PDFs, and multiple documents in different formats into one PDF.
Turn Documents into Professional, Secure and Highly Compatible PDFs.
PDF file format stands out in compatibility, security and has a professional look, so your document can render exactly the same as it should be, regardless of device, software. Also it is often trustworthy and has a higher security to protect privacy.
Enolsoft PDF Converter OCR can convert your documents to PDF, with original integrity, readability and quality retained. It will preserve the formatting for fonts, margins, tables, charts, etc., it also keeps the original layout, same image resolution and so on. There is no need to rebuild your documents after the conversion.
https://www.enolsoft.com/
nge8n.Enolsoft.PDF.Converter.OCR.2.0.0.x64.Multilingual.Portable.rar.html
