05 de Abril de 2026, 21:51 *
Autor Tema: PDF Scanner App Document Scan v2.01  (Leído 31 veces)
« : 27 de Agosto de 2025, 11:06 »
Free Download PDF Scanner App  Document Scan v2.01 | Android | 175.6 MB
Premium version
PDF Scanner - Document Scanner is a free scanner app that helps to scan document with your device using Camera Scanner to scan PDF and open PDF document with this smart scanner app.
Scan documents anytime, anywhere.
Document scanner lets you scan any kind of document. Turn your smartphone into a real multifunctional camera scanner. Doc scanner transforms your paper document to PDF/JPG in just one tap with this free document scanner app.
Document Scanner is the ability to keep all your equipment in your pocket and increase your productivity at work or school. Use PDF Scanner for easy and convenient document scanning. No need for an office scanner any more - install this quick scan app.
PDF Scanner - Document Scanner allows you to scan, import and share any document inside this portable scanner application. Doc scanner app for android detects the corner of the document that you want to scan. You can crop the part of the document that you want to scan. Create multi-page PDF document with fast scanner app PDF document scan.
PDF Scanner - Document Scanner includes
- Scanner
It can transform any type of document into PDF format! The Scanner App is recommended for you and the best scanning app that saves your time and money by using a fast scan. Install this scanner app now!
- Document Scanner
Document Scanner app allows you to edit your files before sharing! This document scanner PDF scanning app save your time. Files are saved to your device as images or PDF documents by using a free pdf scanner and a camera scanner PDF scan.
- Scan to PDF
Scan to PDF can turn any image into a PDF file in a couple of tap. Download Scan to PDF to put your documents in order! Saved to your device PDF documents by using a doc scanner app for android are ready to use with Document scanner.
- Scanner Document App
The Scanner Document app will be able to recognize text in an image and even repair a torn document! Use the document scanning app right now!
- PDF Scanner
PDF scanner will be your document assistant! Download the PDF scanner and enjoy it! This is the best free PDF scanner for documents.
PDF Scanner app Features
- Use your device camera to scan in high resolution. Scanning process includes document border detection, automatic image enhancement, smart background cropping, multiple filter options. Using filters makes your scanned documents clearer and more suitable for different office tasks.
- Convert any paper writing to PDF, such as contracts, invoices, bills and receipts, certificates, notebooks and notes, business cards, etc.
- Share scanned files in PDF or JPEG formats via email, messengers or social networks.
- Print out any scanned documents.
- View scanned files offline anywhere and anytime.
- Document editing before saving includes deleting any page or adding some, choosing the layout of the document, also you can set page s of your PDF document.
- Easy file management - searching and sorting features helps to find the needed document.
- Protect your documents by setting a password to your confidential PDF files.
- Adding a signature and stamp to a document. Sign and seal the necessary scans of documents in the application directly before sharing or printing.
Requirements: Android 7.0+
https://play.google.com/store/apps/details?id=org.smartsoft.pdf.scanner.document.scan&hl=en
1lk5n.PDF.Scanner.App..Document.Scan.v2.01.apk.html
