06 de Abril de 2026, 00:23 *
Autor Tema: White Noise Sleep Sounds v9.6  (Leído 55 veces)
Conectado Conectado
« : 30 de Agosto de 2025, 13:22 »
Free Download White Noise  Sleep Sounds v9.6 | Android | 61.1 MB
Premium version
White noise, sleep sounds and meditation music are best for relaxing, sleeping, meditation and concentration or if you have problems with tinnitus or insomnia.
You can now forget about insomnia and start sleeping better. White noise or brown noise sounds are specifically designed to overcome insomnia by taking your mind into a deep state of relaxation.
You can set the timer and put your app in background or turn off the screen. At the end of the time, the sound fades gently and the application closes by itself. So you do not have to worry about closing the white noise app if you fall asleep. White noise is an ideal application for learning, reading, concentration, meditation and rest.
For a better experience, we recommend you the use of headphones or earphones to listen the relaxing sounds.
Application features
- 30 relaxing sounds with white noise
- helps you sleep by blocking distracting sounds
- timer system that slowly fades audio out
- auto-pause sounds on incoming call
- usage in the background and with other apps
- no streaming is required for playback (no data connection required)
- you can make list of favorite sounds
Requirements: Android 5.0+
https://play.google.com/store/apps/details?id=com.dreamstudio.whitenoise&hl=en
40i5s.White.Noise..Sleep.Sounds.v9.6.apk.html
