05 de Abril de 2026, 13:35 *
Autor Tema: Autodesk Revit 2025.4.3 with Updated Extensions Win x64 Multilanguage  (Leído 64 veces)
« : 31 de Agosto de 2025, 17:14 »
Free Download Autodesk Revit 2025.4.3 with Updated Extensions | 2.9 Gb
Languages Supported *: English US, English UK, Deutsch, Français, Español, Brazilian Português,
Italiano, Русский, Polski, Čeština, Simplified 中文, Traditional 中文, 日本語, 한국어
Autodeskhas releasedREVIT 2025.4.3. Apart from fixes in the detected issues, this update also hosts noteworthy enhancements. All updates are cumulative and include all changes from previously released Revit 2025 updates.
Owner:Autodesk
Product Name:REVIT
Version:2025.4.3 with Updated Extensions *
Supported Architectures:x64
Website Home Page :www.autodesk.com
Languages Supported:multilanguage *
System Requirements:Windows **
Software Prerequisites:pre-installed Autodesk REVIT 2025.0 and above
2025.4.3 Update - Release Date: August 26, 2025
After this update is applied successfully, the build number specified on the Help > About dialog will be:
-    25.4.30.30
-    20250815_1515(x64)
-    2025.4.3
Software embedded in the update executable:
ADP Desktop SDK - version 5.5.54.0
Generative Design for Revit - version 25.5.6.0
Personal Accelerator for Revit 2025 - version 25.4.30.30
Addins Manager for Revit 2025 - version 25.4.30.30
Cloud Models for Revit 2025 - version 25.4.30.30
Core Content for Revit 2025 - version 25.4.30.30
Core Package - Component for Revit 2025 - version 25.4.30.30
Core Package - ATF for Revit 2025 - version 25.4.30.30
Core Package - Cloud for Revit 2025 - version 25.4.30.30
Core Package - CefSharp for Revit 2025 - version 25.4.30.30
Dynamo Core for Revit 2025 - version 25.4.30.30
Dynamo Docs - version 25.4.30.30
Dynamo Samples - version 25.4.30.30
Core Package - RVT Component for Revit 2025 - version 25.4.30.30
TwinMotion Package Component for Revit 2025 - version 25.4.30.30
Unit Schemas for Revit 2025 - version 25.4.30.30
Product Feedback for Revit 2025 - version 25.4.30.30
Carbon Insights for Revit 2025 - version 25.4.30.30
Important Notes - Installation
The Revit 2025.4.3 Update does not support uninstall. Once the Revit 2025.4.3 Update is applied, Revit 2025 cannot be reverted to its pre-update state.
Important Notes
Effective July 1st, 2025, Insight Energy Analysis and Autodesk Green Building Studio are no longer accessible. Autodesk Insight Energy Analysis and Green Building Studio have been retired and replaced by next generation Autodesk Insight Carbon Analysis. To perform analysis, customers will be required to submit their models to the next generation Autodesk Insight from Revit 2023.1 and higher. Effective October 1st, 2025, Autodesk will no longer enable the retrieval of models and analysis results from Insight Energy Analysis and Green Building Studio for customers.
2025.4.3 Update Issues Resolved
General
- Addressed potential RFA Out-of-Bounds Read Vulnerability in Autodesk Revit. More details.
Coordination Model
- Fixed a Coordination Model changes processing glitch and potential unexpected close of Revit that could occur when working with the same Coordination Model in two Revit sessions side-by-side or in two Revit projects in the same Revit session.
- Improved the numbers reporting for modified and deleted elements in Coordination Model Changes.
Import/Export Data Exchange
- Resolved an issue affecting placement and scaling of certain objects linked into Revit via the Data Exchange Connector for Revit.
Export DWG/DXF
- Fixed an issue where hatches were exported incorrectly to CAD formats if the patterned elements were transparent in the Revit view.
Parameters
- Corrected editing of the "Tilt Angle" within the type editor on objects such as lighting fixtures.
Properties Dialog
- Added a new option in Revit.ini "DisableParamSortInMPPAndEditTypeDialog" in section "UserInterface" which sorts parameters in the order of creation, to match the behavior in earlier releases.
Reinforcement
- Fixed an API issue where updaters subscribed to geometry changes are not triggered when free form rebar constraints are edited.
Revit Cloud Model (workshared)
- Updated Revit to load upiconfig.xml from a new location (C:\Program File\Autodesk\Revit XXXX\UPI).
- Fixed the issue where cloud models with a long path are not available for linking.
- Fixed an issue with the Revit Link API to ensure cloud models initiated via API can be published as expected.
Stair
- Fixed an undefined behavior when the cut plane level is equal to the height of the top nosing (tread).
Steel Connections
- Resolved instabilities when opening corrupted models.
User Interface
- Fixed an issue that Revit UI became unresponsive in some cases with Windows 11.
Autodesk Revit, Autodesk's leading Building Information Modeling (BIM) solution, supports multi-discipline teams throughout the project lifecycle. Available individually or as part of the Autodesk architecture, engineering, and construction industry collection, Autodesk Revit features industry-specific tools for architectural design, mechanical, electrical, and plumbing (MEP), structural engineering, and construction.
Autodesk Revit 2025offers new capabilities and enhancements for site design and toposolids, upgrades for modeling and documenting concrete and steel design, in addition to new features for sustainability and carbon analysis, structural analysis, and MEP analysis and fabrication. There are many community ideas realized in Revit 2025, among them sheet collections which benefit efficiency for everyone documenting in Revit, single element and empty arrays for modeling families, and wall joins which improve the experience of placing and manipulating walls, making it more predictable and less prone to error. There's also more connectivity to Autodesk Docs, improvements for openBIM workflows and data exchange, and other project management upgrades and schema improvements.
What's new in Revit 2025
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
*NOTE: For each of the supported languages, the Revit software contains translations for the user interface. Revit does not use language packs. Instead, the base language for the software is determined as follows:
-When installing Revit on a single computer:The language (and locale) for the software is based on the computer's regional settings specified for the operating system.
-When creating a Custom Install:The language (and locale) for the deployment image is based on the regional settings specified for the operating system of the computer used to create the deployment.
Languages for Revit content
In a default Revit installation essential language content packs for the 14 supported languages in Revit will be installed. Essential language content is option within Custom Install workflows.
Revit_2025_4_3.exe
Autodesk Data Exchange Connector for Revit 2025 (v1.8.0)
Autodesk MEP Content Editor Sync v4.3
IFC v25.4.3 for Revit 2025
Uploady
fecc9.Autodesk-Revit-2025-4-3-with-Updated-Extensions.rar
http://peeplink.in/7e66814e5b15
fecc9.Autodesk-Revit-2025-4-3-with-Updated-Extensions.rar.html
