06 de Abril de 2026, 00:57 *
Autor Tema: Hexagon Vero WorkNC 2025.2 Win x64 Multilanguage  (Leído 48 veces)
Conectado Conectado
« : 03 de Septiembre de 2025, 02:38 »
Free Download Hexagon Vero WorkNC 2025.2 | 2.6 Gb
Vero Software, a part of Hexagonhas releasedWorkNC 2025.2is a premium CNC software for surface or solid models in mould, die and tooling businesses for 2 to 5-axis CNC programming. The latest release of WORKNC introduces most required improvements in CAM programming, enhancing user experience and efficiency
Owner:Hexagon
Product Name:WorkNC
Version:2025.2
Supported Architectures:x64
Website Home Page :www.worknc.com
System Requirements:Windows *
What's new in WorkNC 2025.2
Boost your productivity with the multi-directional re-roughing
Experience a faster, simpler, and safer way to program re-roughing toolpaths. This new module lets you create multiple 3+2 re-roughing paths simultaneously for the same tool - with intelligent automation that detects optimal cutting directions and avoids collisions. You stay in control with interactive orientation adjustments, ensuring precision and results tailored exactly to your needs.
Next-Gen Toolpath Interface
Our redesigned interface transforms the way you program toolpaths, making it faster and more intuitive than ever. Easily manage all key 2.5 and 3-axis toolpaths through a modern, streamlined workflow. Edit multiple parameters at once to accelerate your setup and boost productivity. Plus, benefit from intelligent, context-aware help that guides you in real time - exactly when and where you need it.
Smarter Spiral Pattern in Global Roughing
The latest algorithm brings a major leap in pocket machining by simultaneously handling spiral clearing, pass and level transitions, and intelligent pass sequencing. Smooth cutter transitions are automatically applied between passes and levels near the stock, eliminating unnecessary rapid retracts and improving overall efficiency. Tool life is significantly enhanced by avoiding full-width cuts along walls, reducing vibrations. In open pockets, the algorithm adapts automatically with a concentric pattern and micro-lift transitions to deliver optimal machining performance.
Why Choose WORKNC 2025.2?
With a vision to be the go-to CAM solution for precision manufacturing, WORKNC 2025.2 delivers:
-    Easy & Fast Programming - Get parts ready for machining with minimal setup.
-    Efficient Machining - Advanced toolpaths that maximize speed and material removal.
-    Safe Machining - Built-in collision avoidance and optimal tool engagement.
-    High-Quality Finishing - Deliver perfect molds and dies with confidence.
WorkNCCAM software is the premier automatic CNC software for surface or solid models in mold, die and tooling businesses for 2 to 5-axis CNC programming, which perfect for surface or solid models in mould, die and tooling. WorkNCs multi-threaded processing takes advantage of multi-core computers giving blisteringly fast calculation and processing times. Preparation times are also reduced thanks to predefined machining sequences and batch mode toolpathcalculations.
WORKNC 2025.2 | Multi Directional Re-Roughing
Hexagonis a leading global provider of design, measurement and visualisation technologies. Hexagon has more than 14,000 employees in over 40 countries and net sales of about 2,400 MEUR. Our products are used in a broad range of industries including surveying, power and energy, aerospace and defence, construction, safety and security, automotive and manufacturing.Vero Software, a part of Hexagon Manufacturing Intelligence's Production Software business. Hexagon acquired Vero Software, a specialist in CAD/CAM software, in 2014 and has continued to expand and diversify its offering.
889y0.Hexagon-Vero-WorkNC-2025-2.rar.html
